Sunlab (Suntech) ST340UR
Suntech ST340UR is a waterproof GPS tracker with multiple inputs and outputs. The device features 2 digital inputs, 1 configurable input, 1configurable digital output, RS232 interface, 1-Wire, 3-axis accelerometer, jamming detection, speed alert, IP67 water-resistant casing, 450 mAh backup battery, and more.
Parameters (310)
Settings (8)
Flespi parses telemetry data from your Sunlab (Suntech) ST340UR into a standardized JSON and lets you send commands to Sunlab (Suntech) ST340UR via API.
    "device.type.id": "Sunlab (Suntech) ST340UR",
How to send commands to Sunlab (Suntech) ST340UR?
ALT Report Header 24,
Hour Meter
hour_meter
Set travelled time
value: Hour-Meter
auth: Auth
host_backup: Secondary host
port_backup: Secondary port
value: Distance
Reboot device
Report Parameters
reporting
Report generation parameters
Additional Parameters
reporting2
Additional report generation parameters
hbm_stt: Report Additional Fields
jamming: Jamming
vi_on_delay: Virtual Ignition ON Delay
angle_report: Angle
vi_off_delay: Virtual Ignition OFF Delay
vi_on_percent: Virtual Ignition ON Percent
vi_off_percent: Virtual Ignition OFF Percent
jamming_timeout: Jamming Timeout
vi_on_threshold: Virtual Ignition ON Threshold
antitheft_delay1: Anti-Theft State Delay
antitheft_delay2: Anti-Theft Alert Delay
jamming_distance: Jamming Distance
vi_off_threshold: Virtual Ignition OFF Threshold
status
