Sunlab (Suntech) ST3940
Suntech ST3940 is a water-resistant, rugged, hard-cased multi-purpose mini 3G GPS tracker. The device features a built-in 3-axis accelerometer and motion detector, a built-in 3000mA battery, low power consumption, an IP66-compliant casing, and more.
Parameters (287)
Settings (5)
Flespi parses telemetry data from your Sunlab (Suntech) ST3940 into a standardized JSON and lets you send commands to Sunlab (Suntech) ST3940 via API.
    "device.type.id": "Sunlab (Suntech) ST3940",
How to send commands to Sunlab (Suntech) ST3940?
OBD PID 52
ALT Report Header 24,
OBD PID 43
OBD PID 4A
ALT Report Alert ID 71
OBD PID 33
OBD PID 3F
OBD PID 2C
OBD PID 42
OBD PID 41
OBD PID 23
OBD PID 4E
OBD PID 30
OBD PID 2D
OBD PID 1F
OBD PID 44
OBD PID 2E
OBD PID 32
OBD PID 51
OBD PID 0F
OBD PID 0B
OBD PID 10
OBD PID 50
OBD PID 21
OBD PID 4D
OBD PID 3B
OBD PID 3B
OBD PID 1B
OBD PID 4F
OBD PID 4F
OBD PID 4F
OBD PID 4F
OBD PID 1B
OBD PID 2B
OBD PID 22
OBD PID 45
OBD PID 12
OBD PID 58
OBD PID 57
OBD PID 4C
OBD PID 48
OBD PID 0E
can.trip.engine.motorhours
auth: Auth
host_backup: Secondary host
port_backup: Secondary port
Report Parameters
reporting_st3940
Report generation conditions setup
emergency_thres: Sensor threshold
status
