Sunlab (Suntech) ST4215
The Suntech ST4215 is a compact LTE Cat M1 vehicle tracker with a backup battery and jamming detection. It offers geo-fencing, ignition detection, IP67 water and dust resistance, and supports 2G fallback. Additionally, it has an accelerometer, configurable I/O pins, and over-the-air firmware updates.
Parameters (303)
Flespi parses telemetry data from your Sunlab (Suntech) ST4215 into a standardized JSON and lets you send commands to Sunlab (Suntech) ST4215 via API.
    "device.type.id": "Sunlab (Suntech) ST4215",
How to send commands to Sunlab (Suntech) ST4215?
ALT Report Header 24,
