Sunlab (Suntech) ST4310
Suntech ST4310 is a low-cost and compact yet water-resistant and functional GPS tracker with LTE/NB-IoT support. The device features a 3-axis accelerometer, RS232, 1-Wire, 2 inputs and 2 outputs, IP67 casing, and more.
Parameters (303)
Flespi parses telemetry data from your Sunlab (Suntech) ST4310 into a standardized JSON and lets you send commands to Sunlab (Suntech) ST4310 via API.
    "device.type.id": "Sunlab (Suntech) ST4310",
How to send commands to Sunlab (Suntech) ST4310?
ALT Report Header 24,
