Sunlab (Suntech) ST4315
The Suntech ST4315 is a wired tracking device for vehicles with customizable inputs/outputs for various sensors and accessories. It supports external DC power, withstands extreme temperatures, and has IP67 water resistance. Essential features include backup battery support, USB connectivity for configuration, 1-wire temperature sensor support, and LED indication for power and connectivity status.
Parameters (287)
Flespi parses telemetry data from your Sunlab (Suntech) ST4315 into a standardized JSON and lets you send commands to Sunlab (Suntech) ST4315 via API.
    "device.type.id": "Sunlab (Suntech) ST4315",
How to send commands to Sunlab (Suntech) ST4315?
OBD PID 52
ALT Report Header 24,
OBD PID 43
OBD PID 4A
ALT Report Alert ID 71
OBD PID 33
OBD PID 3F
OBD PID 2C
OBD PID 42
OBD PID 41
OBD PID 23
OBD PID 4E
OBD PID 30
OBD PID 2D
OBD PID 1F
OBD PID 44
OBD PID 2E
OBD PID 32
OBD PID 51
OBD PID 0F
OBD PID 0B
OBD PID 10
OBD PID 50
OBD PID 21
OBD PID 4D
OBD PID 3B
OBD PID 3B
OBD PID 1B
OBD PID 4F
OBD PID 4F
OBD PID 4F
OBD PID 4F
OBD PID 1B
OBD PID 2B
OBD PID 22
OBD PID 45
OBD PID 12
OBD PID 58
OBD PID 57
OBD PID 4C
OBD PID 48
OBD PID 0E
