Sunlab (Suntech) ST4345R
This device is a compact and rugged telemetry solution ideal for mobile and stationary applications. It is waterproof with an IP67 rating, equipped with RS-232 for peripheral connections, and an accelerometer for movement analysis. It also features LTE Cat M1 communication, GPS/GLONASS support, and a backup battery, making it perfect for remote asset management in harsh environments.
Parameters (303)
Flespi parses telemetry data from your Sunlab (Suntech) ST4345R into a standardized JSON and lets you send commands to Sunlab (Suntech) ST4345R via API.
    "device.type.id": "Sunlab (Suntech) ST4345R",
How to send commands to Sunlab (Suntech) ST4345R?
ALT Report Header 24,
