Sunlab (Suntech) ST4910
Suntech ST4910 is a battery-operated asset GPS tracking device with LTE support and 57Ah long-life battery. The device features support for various sensors (e.g. temperature, humidity, light, barometric pressure, etc.), Lithium Thionyl replaceable battery with up to 10 years life, IP67-compliant waterproof casing, low battery alert, extremely low power consumption, and more.
Parameters (303)
Flespi parses telemetry data from your Sunlab (Suntech) ST4910 into a standardized JSON and lets you send commands to Sunlab (Suntech) ST4910 via API.
    "device.type.id": "Sunlab (Suntech) ST4910",
How to send commands to Sunlab (Suntech) ST4910?
ALT Report Header 24,
Standard parameter names used: *id* - beacon identification string. Usually it is beacon's UUID or MAC-address *local_name* - Beacons's Local Name *rssi* - BLE signal level. Units = dBm *battery.voltage* - Beacon's battery voltage. Units = volts *battery.voltage.volts* - Beacon's battery voltage in volts (transition field, will be removed after 2026-05-19) *battery.level* - Beacon's battery level. Units = percentage *temperature* - Beacon's temperature. Units = celsius
