Sunlab (Suntech) ST4915
The Suntech ST4915 is a long-life battery-operated asset tracking device with a life-time of up to 10 years, featuring BLE and Wi-Fi support for enhanced geo-location. It includes LTE Cat. M1/NB2-IoT with 2G fallback, waterproof IP67 compliance, a built-in 3-axis accelerometer for collision detection, and LED status indicators. The tracker is designed for asset management with capabilities such as circular geo-fencing and battery life alerts.
Parameters (303)
Flespi parses telemetry data from your Sunlab (Suntech) ST4915 into a standardized JSON and lets you send commands to Sunlab (Suntech) ST4915 via API.
    "device.type.id": "Sunlab (Suntech) ST4915",
How to send commands to Sunlab (Suntech) ST4915?
ALT Report Header 24,
