Sunlab (Suntech) ST4932
The Suntech ST4932 is a rechargeable battery-operated tracker for assets, featuring LTE Cat M1/NB2-IoT and 2G fallback connectivity, a 3-axis accelerometer, and waterproof IP67 casing. It provides up to 4 years of battery life at 1 report per day, circular geo-fencing, motion/collision detection, low power consumption with power saving modes, and LED status indicators for cellular, GPS, and power.
Parameters (303)
Flespi parses telemetry data from your Sunlab (Suntech) ST4932 into a standardized JSON and lets you send commands to Sunlab (Suntech) ST4932 via API.
    "device.type.id": "Sunlab (Suntech) ST4932",
How to send commands to Sunlab (Suntech) ST4932?
ALT Report Header 24,
