Sunlab (Suntech) ST4950BDS
Suntech ST4950BDS is a powerful asset GPS tracker for logistics management, monitoring the cold/supply chain, agriculture, trailers, containers. The device features LTE Cat M1/NB-IoT connectivity, BLE 5.0, Wi-Fi for cell location, 1-Wire for a temperature sensor, temperature, humidity, and barometric pressure sensors, 5,200mAh battery, IP67 compliant casing, and more.
Parameters (302)
Flespi parses telemetry data from your Sunlab (Suntech) ST4950BDS into a standardized JSON and lets you send commands to Sunlab (Suntech) ST4950BDS via API.
    "device.type.id": "Sunlab (Suntech) ST4950BDS",
How to send commands to Sunlab (Suntech) ST4950BDS?
ALT Report Header 24,
