Sunlab (Suntech) ST4955LCB
Suntech ST4955LCB is a 4G solar asset GPS tracker with long-life rechargeable battery. The device features 4G Cat-M1/NB-IoT connectivity, 5.2Ah battery, IP67 water-resistant rugged case, 40mA solar panel, and more.
Parameters (303)
Flespi parses telemetry data from your Sunlab (Suntech) ST4955LCB into a standardized JSON and lets you send commands to Sunlab (Suntech) ST4955LCB via API.
    "device.type.id": "Sunlab (Suntech) ST4955LCB",
How to send commands to Sunlab (Suntech) ST4955LCB?
ALT Report Header 24,
