Sunlab (Suntech) ST600R
Suntech ST600R is a feature-rich vehicle 3G GPS tracker. The device features driving pattern analysis, route deviation, anti-theft alarm, 3-axis accelerometer, multiple 14-pin I/O's, backup battery, jamming detection, geo-fencing, FOTA, and more.
Parameters (297)
Settings (9)
Flespi parses telemetry data from your Sunlab (Suntech) ST600R into a standardized JSON and lets you send commands to Sunlab (Suntech) ST600R via API.
    "device.type.id": "Sunlab (Suntech) ST600R",
How to send commands to Sunlab (Suntech) ST600R?
ALT Report Header 24,
ALT Report Alert ID 71
Hour Meter
hour_meter
Set travelled time
value: Hour-Meter
auth: Auth
host_backup: Secondary host
port_backup: Secondary port
value: Distance
Output 4
output4
Enable/disable output 4
Reboot device
Report Parameters
reporting
Report generation parameters
status
