Suntech ST640
Suntech ST640 is a powerful and compact waterproof 3G GPS tracker. The device features driving pattern analysis, route deviation, anti-theft alarm, 3-axis accelerometer, backup battery, jamming detection, geo-fencing, FOTA, IP67 casing, and more.
Parameters (257)
Settings (9)
Suntech ST640
Flespi parses telemetry data from your Suntech ST640 into a standardized JSON and lets you send commands to Suntech ST640 via API.
    "device.type.id": "Suntech ST640",
How to send commands to Suntech ST640?
ALT Report Alert ID 86
OBD PID 52
ALT Report Header 24,
OBD PID 43
OBD PID 4A
OBD PID 46
OBD PID 33
OBD PID 3F
OBD PID 2C
OBD PID 42
OBD PID 23
Diagnostic trouble code array read from CAN May content list of OBDII codes or list of objects with codes. Standard object parameter names used: *standard* - Protocol standard (J1939, J1708(J1587)) *mid* - Message Identifier (J1708) *sid* - Subsystem Identifier (J1708) *fmi* - Failure Mode Identifier (J1939, J1708) *spn* - Suspect Parameter Number (J1939) *sa* - Source Address (J1939) *oc* - Occurrence Count (J1939) *cm* - Conversion Method (J1939)
OBD PID 4E
OBD PID 31
OBD PID 30
can.dtc.objects
!! temporary parameter, see changelog !! Diagnostic trouble code array read from CAN Standard object parameter names used: *standard* - Protocol standard (J1939, J1708(J1587), OBDII) *mid* - Message Identifier (J1708) *sid* - Subsystem Identifier (J1708) *fmi* - Failure Mode Identifier (J1939, J1708) *spn* - Suspect Parameter Number (J1939) *sa* - Source Address (J1939) *oc* - Occurrence Count (J1939) *cm* - Conversion Method (J1939) *code* - Error code (OBDII)
can.dtc.strings
!! temporary parameter, see changelog !! Diagnostic trouble code array read from CAN May content list of OBDII codes or list of objects with codes. Standard object parameter names used: *standard* - Protocol standard (J1939, J1708(J1587)) *mid* - Message Identifier (J1708) *sid* - Subsystem Identifier (J1708) *fmi* - Failure Mode Identifier (J1939, J1708) *spn* - Suspect Parameter Number (J1939) *sa* - Source Address (J1939) *oc* - Occurrence Count (J1939) *cm* - Conversion Method (J1939)
OBD PID 2D
OBD PID 1F
OBD PID 44
OBD PID 2E
OBD PID 32
OBD PID 0A
OBD PID 03
OBD PID 51
OBD PID 0F
OBD PID 0B
OBD PID 09
OBD PID 10
OBD PID 50
OBD PID 21
ALT Report Alert ID 108
OBD PID 4D
can.monitor.status
Monitor status this drive cycle read from CAN, bitmask
OBD PID 41
Oxygen sensor current read from CAN
OBD PID 3B
Fuel-air equivalence ratio for the corresponding oxygen sensor read from CAN
OBD PID 3B
OBD PID 1B
OBD PID 4F
OBD PID 4F
OBD PID 4F
OBD PID 4F
OBD PID 1B
OBD PID 13
OBD PID 2B
OBD PID 22
OBD PID 45
OBD PID 12
OBD PID 58
OBD PID 57
OBD PID 08
OBD PID 4C
OBD PID 48
OBD PID 0E
can.trip.engine.motorhours
VIN Report
OBD PID 1C
VIN Report
VIN Report
VIN Report
Hour Meter
hour_meter
Set travelled time
value: Hour-Meter
auth: Auth
host_backup: Secondary host
port_backup: Secondary port
value: Distance
Output 4
output4
Enable/disable output 4
Reboot device
Report Parameters
reporting
Report generation parameters
status
payload: Text data to send
More devices from ST SUNLAB (Suntech) (67)
