Sunlab (Suntech) ST8310
Suntech ST8310 is a water-resistant GPS tracker with 4G CAT-1 technology and 2G fallback, that makes it greater in coverage and data sending capacity. The device features 220mAh Li-ion battery, IP67-compliant casing, 3 axis accelerometer, geofencing, jamming detection, configurable report formats, and more.
Parameters (309)
Settings (9)
Flespi parses telemetry data from your Sunlab (Suntech) ST8310 into a standardized JSON and lets you send commands to Sunlab (Suntech) ST8310 via API.
    "device.type.id": "Sunlab (Suntech) ST8310",
How to send commands to Sunlab (Suntech) ST8310?
ALT Report Header 24,
trip.engine.motorhours.hours
Temporary parameter previewing the corrected hours value of trip.engine.motorhours on suntech and queclink; removed once trip.engine.motorhours is corrected to hours
Set Hour-Meter
set_hourmeter
value: Hour-Meter
Set Odometer
set_odometer
value: Odometer
