Sunlab (Suntech) ST940
Suntech ST940 is a is a water-resistant rugged 3G GPS tracker. The device features a 3-axis accelerometer, a 1500 mAh built-in battery, a built-in motion detector, a panic button, IP66-compliant casing, and more.
Parameters (303)
Settings (4)
Flespi parses telemetry data from your Sunlab (Suntech) ST940 into a standardized JSON and lets you send commands to Sunlab (Suntech) ST940 via API.
    "device.type.id": "Sunlab (Suntech) ST940",
How to send commands to Sunlab (Suntech) ST940?
ALT Report Header 24,
Location poll
st910_location_poll
When the device receives this command, it responds with location report.
st910_network
auth: Auth
host_backup: Secondary host
port_backup: Secondary port
Protocol type
st910_prot
type: Type
Report Parameters
st910_reporting
Report generation conditions setup
carry_thres: Threshold
