Tekelek TEK-822
Tekelek TEK-822 is a gas LTE dial gauge with flexible sensor/meter connection options suitable for monitoring fuel tank levels and flow rate. The device features a 3.6V Lithium Thionyl Chloride battery, IP68 water-resistant casing, pressure sensors support, serial data support, and more.
Parameters (44)
Settings (5)
Tekelek TEK-822
Flespi parses telemetry data from your Tekelek TEK-822 into a standardized JSON and lets you send commands to Tekelek TEK-822 via API.
    "device.type.id": "Tekelek TEK-822",
    "protocol.id": "tekelek"
How to send commands to Tekelek TEK-822?
accelerometer.orientation
Accelerometer orientation
bor.reset.status
Brown-out reset status
bund.closed.status
Bund switch closed
bund.status
Bund status
energy.consumed
mA/s
Count of energy used from the previous upload
gnss.fix.duration
go.active.status
GO Active status
gsm.error.code
limit.alarm.status
Alarm of limit violation
liquid.level
cm
Level of liquid in tank
product.model.enum
Product model
radar.firmware.version
Radar FW version
radar.status
Radar status flags bitmask
rtc.failure.status
Real-time clock limp along status
send.attempts
Count of how many attempts it took to send the message
sonic.result.code
Sonic result code
sonic.rssi
Sonic signal strength
wdt.reset.status
Watchdog timer reset status
Activate
activate
Send R3=/R4= command to activate/deactivate device
enable: Activate
fwrev: Firmware Revision
fwver: Firmware Version
hwver: Hardware Version
iccid: SIM card ICCID
cfgver: Config version
network_gsm
Configure GSM network parameters
Set device real time clock
set_rtc
Send R2 command to sync device time from server
Send logged data to server
{"payload":"TEK880,R1=01"}
