ThinkPower TE-304F
Thinkpad TE-304F is a compact IP67 LTE vehicle tracker with GNSS and a built-in backup battery for reliable fleet monitoring. It supports LTE Cat-1/Cat-M1/NB-IoT with 2G fallback, wide-voltage power, and interfaces including B+/ACC, RS232, sensor, MIC, and SOS. The device works with Bluetooth sensors for doors, tire pressure, temperature/humidity, beacons, and angular rate. A G-sensor detects harsh events like rapid acceleration, sharp turns, hard braking, collisions, and speeding. Supports ignition detection, relay-based remote fuel cut-off, RFID/iButton driver ID, and tight-space installations.
Parameters (95)
ThinkPower TE-304F
Flespi parses telemetry data from your ThinkPower TE-304F into a standardized JSON and lets you send commands to ThinkPower TE-304F via API.
    "device.type.id": "ThinkPower TE-304F",
    "protocol.id": "thinkpower"
How to send commands to ThinkPower TE-304F?
ain.alarm.status
Analog input alarm status
can.engine.idle.duration
can.engine.oil.consumption
can.idle.engine.rpm
can.idle.vehicle.speed
direction.alarm.status
Heading angle threshold alarm
gps.jamming.event
GPS signal jamming detected
gps.spoofed.event
GPS signal spoofing detected
high.temperature.alarm
High temperature alarm
lbs.location.status
LBS location state false - location lost, true - location success
payload.source.id
ID of peripheral device that sent payoad
reverse.overspeeding.alarm.status
Reverse gear overspeeding alarm
Text: Query port
{"text":"#M#set port"}
Text: Get position
{"text":"#M#pos"}
Text: Reboot device
{"text":"#M#reboot"}
Binary: Action reset
Binary: Output control - digital output 2 to ON
