ThinkPower TE-304F-BASIC
Thinkpower TE-304F-BASIC is a compact 4G vehicle tracking terminal designed for modern fleet management and harsh environments. It supports LTE Cat-1/M1/NB with 2G fallback, GNSS positioning, wide-voltage power input, and multiple interfaces including B+/ACC, RS232, and sensor inputs for RFID readers or fuel-cutoff and ignition control. The built-in backup battery ensures continued operation, while the integrated G-sensor detects aggressive driving events such as rapid acceleration, sharp turns, hard braking, collisions, and speeding. Its rugged IP67-rated housing enables reliable installation in tight or demanding vehicle locations.
Parameters (95)
Flespi parses telemetry data from your ThinkPower TE-304F-BASIC into a standardized JSON and lets you send commands to ThinkPower TE-304F-BASIC via API.
    "device.type.id": "ThinkPower TE-304F-BASIC",
    "protocol.id": "thinkpower"
How to send commands to ThinkPower TE-304F-BASIC?
ain.alarm.status
Analog input alarm status
can.engine.idle.duration
can.engine.oil.consumption
can.idle.engine.rpm
can.idle.vehicle.speed
direction.alarm.status
Heading angle threshold alarm
gps.jamming.event
GPS signal jamming detected
gps.spoofed.event
GPS signal spoofing detected
high.temperature.alarm
High temperature alarm
lbs.location.status
LBS location state false - location lost, true - location success
payload.source.id
ID of peripheral device that sent payoad
reverse.overspeeding.alarm.status
Reverse gear overspeeding alarm
Text: Query port
{"text":"#M#set port"}
Text: Get position
{"text":"#M#pos"}
Text: Reboot device
{"text":"#M#reboot"}
Binary: Action reset
Binary: Output control - digital output 2 to ON
