Tracksmart GMS-50T-TRK
Tracksmart GSM-50T-TRK is a cutting-edge GPS tracking device for trailers, intermodal containers, rail cars, heavy construction, agricultural equipment, etc. The device features a solar panel that extends tracker operation in absence of external power supply. The tracker supports multiple accessories and sensors, FOTA, and features memory for 5 000 events,  extremely low power consumption, and a weather-proof case.
Parameters (33)
Settings (15)
Flespi parses telemetry data from your Tracksmart GMS-50T-TRK into a standardized JSON and lets you send commands to Tracksmart GMS-50T-TRK via API.
    "device.type.id": "Tracksmart GMS-50T-TRK",
    "protocol.id": "telitek"
How to send commands to Tracksmart GMS-50T-TRK?
gsm.earfcn
gsm.network.name
gsm.pcid
All information
all_settings
Retrieve all device settings.
GPRS APN
GPRS connection APN configuration
user: APN User
imsi: IMSI
fwver: Firmware Version
hwver: Hardware Version
fwdate: Firmware Updated Date
modem_ver: Modem Version
Device Name
device_name
Device name configuration
Power Saving Mode
features
enabled: Power Saving mode
FW Server
fw_server
Connect to FW OTA Server
ip: IP Address
Report interval in power saving mode
interval
Valid when power saving mode is ON.
Keep Alive Interval
keep_alive
Device connection keep alive interval configuration
Locate
locate
Locate the device.
Motion Sensor Accuracy
motion
Motion sensor sensitivity configuration
sensitivity: Sensitivity
Reset
Reset the device.
Server
GPRS connection server configuration. Setting changes are applied after device reboot.
ip: IP Address
Speeding Control
speeding
Speeding control configuration
speeding: Speeding Enabled
detection: Detection Time
Tracing Configuration
tracing
Tracing configuration
time: Time Tracing
distance: Distance Motion Detection
Wakeup Period
wakeup
Device not moving wakeup period configuration
period: Wakeup Period
More devices from Telitek
No results found.
