anchor.distance
Distance to anchor/area center
gnss.type
gps.module.version
GPS module version
gsm.firmware.version
gsm.pcid
message.content
Message content
message.detail
Message detail
modem.name
Name of the modem
normal.mode.status
Normal mode status
test.mode.status
Beacon / Wi-Fi filter
beacon_wifi_filter
Beacon display, BLE/Wi-Fi filtering and TAG reading
wifi_scan: Wi-Fi AP scan
ble_filter: Filter BLE by beacon name
tag_reading: TAG reading
show_beacon_name: Show beacon name on display
BLE scanning
ble_scanning
BLE beacon scanning configuration
ble_scan: BLE beacon scan
preserve_time: Beacon data preserve time (seconds)
sort_and_send: Sort and send mode
beacon_location: Beacon location enabled
low_battery_warning: Low battery warning
GPS configuration
gps_configuration
GPS sleep time, search time, A-GPS, economy mode and position validity
agps_mode: A-GPS mode
sleep_time: Sleep time (seconds)
max_search_time: Max search time (seconds)
validity_period: Position validity period (seconds)
realtime_economy: Realtime economy mode
Motion detection
motion_detection
GPS motion sensor control and sensitivity (cannot be used simultaneously with ManDown)
enabled: Motion sensor
sensitivity: Sensitivity (mG)
On-screen message
on_screen_message
Show a text message on device display
RAW tracking
raw_tracking
Start or stop RAW DATA endless tracking. Reports will be stored as TRX messages
interval: Interval (minutes)
service_state: Service state
beacon_datablocks: Data sources
Request location
request_location
Request GPS position from device. Response will be stored as LOC message
Request RAW location
request_raw_location
Request RAW DATA location measurement. Response will be stored as LOX message
Server connection
server_connection
GPRS connectivity, APN, server address and port
port: Server port
address: Server address
gprs_usage: GPRS usage
SRD transceiver
srd_transceiver
SRD transceiver sleep and beacon search time
sleep_time: Sleep time (minutes)
search_time: Beacon search time (seconds)
