Twig Protector Pro
Twig Protector Pro is an emergency GPS tracker that includes an alarm button, automatic man-down function, Amber Alert, and optional TWIG Button wireless alarm. The predefined emergency protocol transmits the last known user position and opens a two-way voice connection to alarms receiving center (ARC). High-performance GPS receiver with turn-key AGPS feed is complemented with TWIG Beacon indoor location. Excellent operating times even in continuous GPS monitoring are achieved through advanced technology and large-capacity battery.
Parameters (52)
Settings (10)
Twig Protector Pro
Flespi parses telemetry data from your Twig Protector Pro into a standardized JSON and lets you send commands to Twig Protector Pro via API.
    "device.type.id": "Twig Protector Pro",
    "protocol.id": "twig"
How to send commands to Twig Protector Pro?
anchor.distance
Distance to anchor/area center
gnss.type
gps.module.version
GPS module version
gsm.firmware.version
gsm.pcid
message.content
Message content
message.detail
Message detail
modem.name
Name of the modem
normal.mode.status
Normal mode status
test.mode.status
Beacon / Wi-Fi filter
beacon_wifi_filter
Beacon display, BLE/Wi-Fi filtering and TAG reading
wifi_scan: Wi-Fi AP scan
ble_filter: Filter BLE by beacon name
tag_reading: TAG reading
show_beacon_name: Show beacon name on display
BLE scanning
ble_scanning
BLE beacon scanning configuration
ble_scan: BLE beacon scan
preserve_time: Beacon data preserve time (seconds)
sort_and_send: Sort and send mode
beacon_location: Beacon location enabled
low_battery_warning: Low battery warning
GPS configuration
gps_configuration
GPS sleep time, search time, A-GPS, economy mode and position validity
agps_mode: A-GPS mode
sleep_time: Sleep time (seconds)
max_search_time: Max search time (seconds)
validity_period: Position validity period (seconds)
realtime_economy: Realtime economy mode
Motion detection
motion_detection
GPS motion sensor control and sensitivity (cannot be used simultaneously with ManDown)
enabled: Motion sensor
sensitivity: Sensitivity (mG)
On-screen message
on_screen_message
Show a text message on device display
message: Message text
RAW tracking
raw_tracking
Start or stop RAW DATA endless tracking. Reports will be stored as TRX messages
interval: Interval (minutes)
service_state: Service state
beacon_datablocks: Data sources
Request location
request_location
Request GPS position from device. Response will be stored as LOC message
Request RAW location
request_raw_location
Request RAW DATA location measurement. Response will be stored as LOX message
Server connection
server_connection
GPRS connectivity, APN, server address and port
port: Server port
address: Server address
gprs_usage: GPRS usage
SRD transceiver
srd_transceiver
SRD transceiver sleep and beacon search time
sleep_time: Sleep time (minutes)
search_time: Beacon search time (seconds)
Send custom MPTP command from Central Station to Mobile Telematics Terminal
Stop simple tracking process started by TRC or TRS command
{"payload":"?STO"}
Request last known position. Response will be stored as message
{"payload":"?LOC_0"}
Request stored SRD beacon report from device memory. Response will be stored as LOB message
{"payload":"?LOB"}
Request position: Attempt to acquire a fresh position fix. Response will be stored as message
{"payload":"?LOC_1"}
Request device info (SW version, GPS version, IMEI, GSM module). Response will be stored as SIR message
{"payload":"?SIR"}
