UMKa300
UMKa300 is a compact GPS/GLONASS tracking device with dual-SIM support working over GSM 900/1800, GPRS Multi-slot Class 12. The terminal features a 3-axis accelerometer, RS-485 and 1-Wire interfaces (+ optional RS-232), 4 inputs and 1 output, FOTA, built-in antennas (optional external antennas), optional battery, and more.
UMKa300 supports the new wialon_combine protocol.
Parameters (30)
UMKa300
Flespi parses telemetry data from your UMKa300 into a standardized JSON and lets you send commands to UMKa300 via API.
    "device.type.id": "UMKa300",
    "protocol.id": "wialon-combine"
How to send commands to UMKa300?
Record type 9
Record type 2
Record type 2
Record type 12
Record type 4
Record type 4
Record type 4
Record type 4
Record type 4
Record type 4
Record type 10
Record type 1
Record type 1
Record type 1
Record type 1
Record type 1
Record type 1
Record type 1
Record type 13
Record type 13
payload: Command payload as text or HEX string
Send string 1234
{"payload":"1234"}
Send string 1234 in hex
{"hex":true,"payload":"31323334"}
