UMKa301
UMKa301 is an innovative GPS/GLONASS tracking device working over the new wialon-combine protocol and featuring dual-SIM support over GSM 900/1800, GPRS Multi-slot Class 12, voice communication, and IoT connectivity. The terminal features a 3-axis accelerometer, RS-485 and 1-Wire interfaces (+ optional RS-232 and CAN), 4 inputs and 1 output, built-in battery, FOTA, Bluetooth, built-in antennas, optional SD card, optional extension slot, and more.
UMKa301 supports the new wialon_combine protocol.
Parameters (30)
UMKa301
Flespi parses telemetry data from your UMKa301 into a standardized JSON and lets you send commands to UMKa301 via API.
    "device.type.id": "UMKa301",
    "protocol.id": "wialon-combine"
How to send commands to UMKa301?
Record type 9
Record type 2
Record type 2
Record type 12
Record type 4
Record type 4
Record type 4
Record type 4
Record type 4
Record type 4
Record type 10
Record type 1
Record type 1
Record type 1
Record type 1
Record type 1
Record type 1
Record type 1
Record type 13
Record type 13
payload: Command payload as text or HEX string
Send string 1234
{"payload":"1234"}
Send string 1234 in hex
{"hex":true,"payload":"31323334"}
