X3Tech NT40 OBD
Tracker NT40 OBD is a compact vehicle GPS tracker with 4G Cat-1/2G connectivity, OBD-II plug-and-play installation, and IP65 dust and water resistance. It features high-sensitivity GPS, remote immobilization, OTA firmware updates, odometer and hour meter, accelerometer-based virtual ignition, internal backup battery, and multiple configuration options via SMS, GPRS, and serial. The device supports economic sleep mode, connector removal alarm, and operates in a wide voltage range (9-36V), making it suitable for various vehicles.
Parameters (56)
X3Tech NT40 OBD
Flespi parses telemetry data from your X3Tech NT40 OBD into a standardized JSON and lets you send commands to X3Tech NT40 OBD via API.
    "device.type.id": "X3Tech NT40 OBD",
    "protocol.id": "x3tech"
How to send commands to X3Tech NT40 OBD?
battery.full.event
Battery fully charged event
Protocol Number 0x13
Protocol Number 0x94
Protocol Number 0x90,
payload.size
Payload data size in bytes
Protocol Number 0x15
Location Data Protocol
location_data_protocol
version: Protocol Version
Where
where
Obtain real-time position
{"payload":"DWXX#"}
