X3Tech XT40 OBD
The OBD II GARANTIA is a compact vehicle and motorcycle GPS tracker with OBDII connector, supporting 4G Cat-1/2G connectivity, high-sensitivity GPS/GLONASS/BDS/LBS, and IP65 protection. It features drive behavior monitoring, remote immobilization, OTA firmware updates, odometer and hourmeter, SMS/GPRS/SERIAL configuration, internal battery for backup, and sleep mode for power saving. The device is easy to install, supports remote updates, and is suitable for cars, trucks, buses, and motorcycles.
Parameters (56)
X3Tech XT40 OBD
Flespi parses telemetry data from your X3Tech XT40 OBD into a standardized JSON and lets you send commands to X3Tech XT40 OBD via API.
    "device.type.id": "X3Tech XT40 OBD",
    "protocol.id": "x3tech"
How to send commands to X3Tech XT40 OBD?
battery.full.event
Battery fully charged event
Protocol Number 0x13
Protocol Number 0x94
Protocol Number 0x90,
payload.size
Payload data size in bytes
Protocol Number 0x15
Location Data Protocol
location_data_protocol
version: Protocol Version
Where
where
Obtain real-time position
{"payload":"DWXX#"}
