Wialon Local AI agent connector: operate your own Wialon server with your agent
Give your flespi AI agent access to a Wialon Local installation to operate it on your behalf
The Wialon Local connector gives your flespi AI agent access to a Wialon Local installation, the Wialon server you run yourself: Wialon documentation and API expertise plus direct work with its data on your behalf. Use it to manage a Wialon Local installation paired with flespi, on its own without any flespi pairing, or side by side with a Wialon Hosting account.
New to flespi AI agents? Read the flespi AI agents article first: what agents are, how they reason and sleep, and how approvals keep you in control. This article covers the Wialon Local side of the story.
1. Connect the installation
Two configuration fields:
  • url: the address of your Wialon Local monitoring or CMS Manager site, e.g. https://wialon.example.com, without a path or a trailing slash. The site must be reachable from the internet over https with a valid certificate: the agent never sends your token over a plain connection. Wialon Local 2604 or newer is supported. An older release is refused with a message naming the release required, so upgrading the installation is the way to connect it.
  • token: a Wialon access token issued by your own site. Open https://<your site>/login.html?client_id=flespi&access_type=-1&activation_time=0&duration=0&lang=en&flags=0, sign in with your Wialon user and confirm the access request. The site then redirects to an address carrying access_token=, and the 72-character value after it is your token. The link asks for full access (access_type=-1) and no expiry (duration=0).
Copy the token from the address bar of the page you land on:
copy the wialon access token from the redirect URL
Create a connector of the wialon_local type with the url and the token:
create a wialon local AI connector with the site address and the token
Assign the connector to your agent (create one if you have none yet), choosing what the agent may change on its own: the default rule for account-changing Wialon API calls and, above it, rules for the parts of the account you trust it with. The targets are the families of the Wialon API: units and their commands, geofences, drivers and trailers, notifications and jobs, report templates, users and tokens, account and billing, and the rest such as files, routes, orders and messages. The rules button next to the connector in the Connectors block of AgentBox opens these rules at any time:
the Wialon API Mutate rules of the connector in AgentBox
The token defines the ceiling: the agent works strictly within the token's access scope and recommends a broader token when a task is out of reach, rather than attempting calls that will fail. An expired or revoked token surfaces to the agent at its next call, and it asks you to reconnect the connector with a fresh one. A token of the server-level user reaches every account on the installation, and Wialon places new items in accounts below it, so the agent asks which account an item belongs in before creating it.
2. Work with the agent
The agent knows Wialon: it consults the official Wialon Local documentation and API reference on its own, for the release your installation runs, so you can discuss units, resources, users, geofences, sensors, notifications, and reports the way you would with a Wialon engineer. It also knows what is specific to your server: the installed release, the address devices connect to, and the modules your installation grants, so it works with what the installation has rather than assuming the Wialon Hosting feature set.
the AI agent reports the wialon local release and inventory
Reading the installation is free and autonomous: the agent searches items, loads messages, executes and reads reports, and analyzes the results computationally, all through a read-only surface that physically cannot change anything.
When the installation is paired with flespi, the agent reasons across both systems: for example, it checks how flespi data lands in Wialon. With a Wialon Hosting connector assigned to the same agent, it reasons across the two Wialon systems too, keeping them apart: a migration from Wialon Hosting to your own server starts with the agent comparing the units by unique ID and looking up every hardware type on the installation itself, and the plan is yours to approve before anything is created:
the AI agent compares the wialon local installation with the wialon hosting account
The connected installation's data stays between you and the agent: it never leaks into other accounts or shared knowledge. A Wialon notification can wake the agent: its request action posts to a webhook address the agent gives you, and the handler reacts the moment the condition fires. Without one, a monitoring task checks the installation on its own schedule.
Every account-changing Wialon API call goes through the agent approval rules as the wialon_local_api_mutate operation type, and by default each call becomes an approval request. You review the exact call and its parameters before approving, one request per call whichever system it targets:
approval requests of wialon local and wialon hosting mutation calls
Mind what the default protects before relaxing it: the mutation surface includes creating and deleting units, changes to their properties, users and their access rights, token operations, and account and billing changes. Rather than switching the whole operation to automatic execution, add a rule for the part you delegate, for example unit commands on automatic execution while everything else still asks. Executed mutations land in the agent conversation history as wialon_local_api_mutate_executed records, and every Wialon API call the agent performs, reads included, is recorded in the connector logs with the operation, target, and result:
wialon local connector logs with the agent operations
To put the agent in front of the people you serve rather than yourself, pair the connector with a persona: the agent takes your name, speaks their vocabulary, and under branded disclosure never mentions flespi.
A system of yours that has no connector type of its own, an ERP, a ticketing system or the intake of an authority, joins through the HTTP API connector: the agent bridges it with your Wialon Local installation, reading one side and writing the other under your approval rules.
The Wialon Local connector is one of several an agent can hold: browse the full connector list to give your agent more capabilities.
