Assistant-telematics protocol
Parse and decode Assistant Telematics binary messages into JSON. Get parsed data from Assistant Telematics devices via REST API and MQTT. Forward normalized data from Assistant Telematics trackers to AWS, Azure.
flespi parses the Assistant-telematics protocol messages into a JSON object with the fields listed below in the Parameters tab.
To connect your tracker using the Assistant-Telematics protocol, you need to have a assistant-telematics channel created first.
Tachograph functionality
You can use tachograph-related functionality with AVT110 and AVT111 devices.
Tachograph files can be downloaded with the Request tachograph file command or automatically with the Automatic file request option in the device configuration. The Cancel tacho file request setting in the Tacho tab cancels the current download.
Mandatory conditions for proper operation:
  • The company's card number in the configuration of the device must match the card number of the connected device Tacho Bridge Card.
  • Ignition in the vehicle must be turned ON.
  • The Tacho Bridge App authorization application must be configured and connected according to the instructions.
Packet head RPT
Packet head DFI,
Packet head RPT
battery.charging.state
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head DFI
beidou.visible.satellites
Packet head RPT
Packet head RPT
Event type 44: BLE Slave Connect Event,
Packet head RPT
ble.dout
BLE digital output state
Packet head RPT
Packet head DFI,
Packet head VER
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
can.carbon.dioxide.exhausted
Packet head RPT
Event type 45: CANBUS Info Alarm Event,
Packet head RPT
Packet head RPT
Packet head CMI,
Packet head DFI
can.controller.hardware.version
Controller hardware version read from CAN
Packet head DFI
Packet head DFI
Packet head DFI
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
can.driver.door.status
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head RPT
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
can.idle.fuel.consumed
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
can.passenger.door.status
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
can.pto.run.time
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
can.retarder.time
Total retarder usage time read from CAN
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
can.tpms.indicator.status
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head RPT
can.vessel.direction
Vessel compass heading read from CAN bus (NMEA2000)
Packet head RPT
can.water.depth
Water depth read from CAN bus
Packet head RPT
can.water.speed
Speed through water read from CAN bus (NMEA2000)
Packet head RPT
Packet head RPT
can.wind.direction
rad
Wind direction read from CAN bus bus
Packet head RPT
can.wind.speed
m/s
Wind speed read from CAN bus
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head DFI,
Packet head VER
device.illuminance
Packet head RPT
Packet head RPT
Packet head DFI,
Packet head RPT
distance.alarm
Distance alarm detected
Packet head RPT
Packet head RPT
Packet head DFI,
Packet head RPT
ecl.trigger.bitmask
ECL (Event Driver Command List) trigger mask - bitmask of trigger conditions that fired the ECL alarm
Packet head RPT
Packet head RPT
Packet head RPT
Event Type,
Packet head RPT
event.id
Event type 43: ECL Trigger alarm event,
Packet head RPT
event.name
Protocol-specific event name
Packet head RPT
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head RPT
galileo.position.satellites
Packet head DFI
galileo.visible.satellites
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
glonass.visible.satellites
Packet head RPT
Packet head DFI
Packet head DFI
gps.visible.satellites
Packet head RPT
Packet head QNI,
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head DFI,
Packet head QNI,
Packet head RPT
gsm.network.type.enum
Packet head DFI,
Packet head QNI,
Packet head RPT
Packet head QNI,
Packet head RPT
Packet head DFI
Packet head QNI
Packet head QNI
Packet head QNI
Packet head DFI,
Packet head VER
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
main.power.low.status
Main power low status
Packet head RPT
message.seqnum
Packet head GAV,
Packet head GSV,
Packet head LSV,
Packet head RPT
Packet head VER
Packet head RPT
network.ip.address
IP address of the network
Packet head QNI
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head BMR
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head GAV,
Packet head GSV,
Packet head LSV
Packet head DFI,
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head RPT
Packet head RPT
Packet head GAV,
Packet head GSV,
Packet head HBD,
Packet head LSV,
Packet head RPT,
Packet head VER
Packet head RPT
rf433.channel
RF433 channel number (0-19 maps to 433.0-434.9 MHz)
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head GAV,
Packet head GSV,
Packet head LSV
Packet head RPT
Packet head RPT
Packet head RPT
sensor.x.acceleration
Acceleration sensor X-axis value
Packet head RPT
sensor.y.acceleration
Acceleration sensor Y-axis value
Packet head RPT
sensor.z.acceleration
Acceleration sensor Z-axis value
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
tacho.card.reader.status
Tacho card reader state
Packet head DFI
Packet head DFI,
Packet head RPT
tacho.communication.state
Tacho communication state
Packet head DFI,
Packet head RPT
tacho.communication.state.enum
Tacho communication state, 0 - no communication, 1 - online, 2 - error, 3 - not supported
Packet head DFI,
Packet head RPT
tacho.download.state
Tacho remote DDD download state
Packet head DFI,
Packet head RPT
tacho.download.state.enum
Tacho remote DDD download state, 0 - disabled, 1 - enabled, 2 - error, 3 - not supported
Packet head DFI,
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
tacho.driving.direction
Packet head DFI,
Packet head RPT
Packet head RPT
tacho.file.state
Tachograph file state flags description
Packet head RPT
Packet head RPT
tacho.kline.bus.state
Tacho D8/K-Line bus state
Packet head DFI,
Packet head RPT
tacho.kline.bus.state.enum
Tacho D8/K-Line bus state, 0 - sleep, 1 - active, 2 - error, 3 - not used
Packet head DFI,
Packet head RPT
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head RPT
Packet head RPT
tacho.state
Tachograph state flags description
Packet head RPT
Packet head RPT
tacho.state.error
Tachograph state error description
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
tilt.event
Tilt event
Packet head RPT
Packet head GAV,
Packet head GSV,
Packet head LDP,
Packet head LSV,
Packet head RPT
Packet head GAV,
Packet head GSV,
Packet head LSV,
Packet head RPT
tire
Axle and tire index
Packet head RPT
Packet head RPT
Packet head RPT
tire.underpressure.status
Tire underpressure
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head RPT
Packet head RPT
upgrade.status.name
Upgrade status
Packet head RPT
Packet head RPT
Packet head CMI,
Packet head DFI,
Packet head RPT
Packet head CMI,
Packet head DFI
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
text: Text payload
Toggle Digital output
{"text":"AT@OUT=at,1,0,2,0,0001#"}
Get Server Information Settings
{"text":"AT@SIS?at,,0001#"}
request_tachograph_file
