Assistant Telematics AVT110
AVT110 is waterproof device developed for light and heavy machine vehicles, trucks, trailers and motorcycles. The tracker supports all Tachograph models. It includes 3 CAN interfaces (2 CAN + K-line). DDD files are downloadable with an option to receive a real Tachograph data regardless of ignition status, and read DTC from light vehicles. Tracker have built-in BLE and multiple interfaces, which support BLE accessories (fuel sensor, fuel cap, temp & hum., angle sensors & beacons). Thermograph, TPMS readings are supported via RS-232 serial port.
Parameters (317)
Settings (30)
Flespi parses telemetry data from your Assistant Telematics AVT110 into a standardized JSON and lets you send commands to Assistant Telematics AVT110 via API.
    "device.type.id": "Assistant Telematics AVT110",
    "protocol.id": "assistant-telematics"
How to send commands to Assistant Telematics AVT110?
Packet head RPT
Packet head DFI,
Packet head RPT
battery.charging.state
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head DFI
beidou.visible.satellites
Packet head RPT
Packet head RPT
Event type 44: BLE Slave Connect Event,
Packet head RPT
ble.dout
BLE digital output state
Packet head RPT
Packet head DFI,
Packet head VER
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
can.carbon.dioxide.exhausted
Packet head RPT
Event type 45: CANBUS Info Alarm Event,
Packet head RPT
Packet head RPT
Packet head CMI,
Packet head DFI
can.controller.hardware.version
Controller hardware version read from CAN
Packet head DFI
Packet head DFI
Packet head DFI
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
can.driver.door.status
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head RPT
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
can.idle.fuel.consumed
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
can.passenger.door.status
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
can.pto.run.time
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
can.retarder.time
Total retarder usage time read from CAN
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
can.tpms.indicator.status
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head RPT
can.vessel.direction
Vessel compass heading read from CAN bus (NMEA2000)
Packet head RPT
can.water.depth
Water depth read from CAN bus
Packet head RPT
can.water.speed
Speed through water read from CAN bus (NMEA2000)
Packet head RPT
Packet head RPT
can.wind.direction
rad
Wind direction read from CAN bus bus
Packet head RPT
can.wind.speed
m/s
Wind speed read from CAN bus
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head DFI,
Packet head VER
device.illuminance
Packet head RPT
Packet head RPT
Packet head DFI,
Packet head RPT
distance.alarm
Distance alarm detected
Packet head RPT
Packet head RPT
Packet head DFI,
Packet head RPT
ecl.trigger.bitmask
ECL (Event Driver Command List) trigger mask - bitmask of trigger conditions that fired the ECL alarm
Packet head RPT
Packet head RPT
Packet head RPT
Event Type,
Packet head RPT
event.id
Event type 43: ECL Trigger alarm event,
Packet head RPT
event.name
Protocol-specific event name
Packet head RPT
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head RPT
galileo.position.satellites
Packet head DFI
galileo.visible.satellites
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
glonass.visible.satellites
Packet head RPT
Packet head DFI
Packet head DFI
gps.visible.satellites
Packet head RPT
Packet head QNI,
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head DFI,
Packet head QNI,
Packet head RPT
gsm.network.type.enum
Packet head DFI,
Packet head QNI,
Packet head RPT
Packet head QNI,
Packet head RPT
Packet head DFI
Packet head QNI
Packet head QNI
Packet head QNI
Packet head DFI,
Packet head VER
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
main.power.low.status
Main power low status
Packet head RPT
message.seqnum
Packet head GAV,
Packet head GSV,
Packet head LSV,
Packet head RPT
Packet head VER
Packet head RPT
network.ip.address
IP address of the network
Packet head QNI
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head BMR
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head GAV,
Packet head GSV,
Packet head LSV
Packet head DFI,
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head RPT
Packet head RPT
Packet head GAV,
Packet head GSV,
Packet head HBD,
Packet head LSV,
Packet head RPT,
Packet head VER
Packet head RPT
rf433.channel
RF433 channel number (0-19 maps to 433.0-434.9 MHz)
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head GAV,
Packet head GSV,
Packet head LSV
Packet head RPT
Packet head RPT
Packet head RPT
sensor.x.acceleration
Acceleration sensor X-axis value
Packet head RPT
sensor.y.acceleration
Acceleration sensor Y-axis value
Packet head RPT
sensor.z.acceleration
Acceleration sensor Z-axis value
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
tacho.card.reader.status
Tacho card reader state
Packet head DFI
Packet head DFI,
Packet head RPT
tacho.communication.state
Tacho communication state
Packet head DFI,
Packet head RPT
tacho.communication.state.enum
Tacho communication state, 0 - no communication, 1 - online, 2 - error, 3 - not supported
Packet head DFI,
Packet head RPT
tacho.download.state
Tacho remote DDD download state
Packet head DFI,
Packet head RPT
tacho.download.state.enum
Tacho remote DDD download state, 0 - disabled, 1 - enabled, 2 - error, 3 - not supported
Packet head DFI,
Packet head RPT
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head DFI,
Packet head RPT
tacho.driving.direction
Packet head DFI,
Packet head RPT
Packet head RPT
tacho.file.state
Tachograph file state flags description
Packet head RPT
Packet head RPT
tacho.kline.bus.state
Tacho D8/K-Line bus state
Packet head DFI,
Packet head RPT
tacho.kline.bus.state.enum
Tacho D8/K-Line bus state, 0 - sleep, 1 - active, 2 - error, 3 - not used
Packet head DFI,
Packet head RPT
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head RPT
Packet head RPT
tacho.state
Tachograph state flags description
Packet head RPT
Packet head RPT
tacho.state.error
Tachograph state error description
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
tilt.event
Tilt event
Packet head RPT
Packet head GAV,
Packet head GSV,
Packet head LDP,
Packet head LSV,
Packet head RPT
Packet head GAV,
Packet head GSV,
Packet head LSV,
Packet head RPT
tire
Axle and tire index
Packet head RPT
Packet head RPT
Packet head RPT
tire.underpressure.status
Tire underpressure
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head RPT
Packet head RPT
upgrade.status.name
Upgrade status
Packet head RPT
Packet head RPT
Packet head CMI,
Packet head DFI,
Packet head RPT
Packet head CMI,
Packet head DFI
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
BLE Broadcast Setting
bbs
mode: Working Mode
report_main_server: Report to Main Server
report_second_server: Report to Second Server
transparent_data_length: Transparent Data Length
transparent_data_interval: Transparent Data Interval
CAN bus Setting
can
mode: CAN Mode
can_report: CAN Reporting When Ignition On
vin_enable: Vehicle Identification (VIN)
doors_enable: Doors
range_enable: Range
lights_enable: Lights
can_report_igf: CAN Reporting When Ignition Off
odometer_enable: Total Distance (Odometer)
motor_rpm_enable: Motor RPM
abs_status_enable: ABS Status
engine_rpm_enable: Engine RPM
esc_status_enable: ESP/ESC Status
fuel_level_enable: Fuel Level
pto_status_enable: PTO Status
tcs_status_enable: ASR/TCS Status
battery_soc_enable: Battery State of Charge
battery_soh_enable: Battery State of Health
motor_power_enable: Motor Power
tacho_speed_enable: Tachograph Speed
adblue_level_enable: AdBlue Level
indicators_1_enable: Detailed Information/Indicators 1
indicators_2_enable: Detailed Information/Indicators 2
motor_torque_enable: Motor Torque
airbag_status_enable: Airbag Status
can1_resistor_enable: CAN1 120 ohms Resistor
can2_resistor_enable: CAN2 120 ohms Resistor
trip_distance_enable: Trip Distance
vehicle_speed_enable: Vehicle Speed
ignition_event_enable: Ignition Event
nmea2000_depth_enable: Depth Below Transducer
tacho_distance_enable: Tachograph Distance
axle_weight_1st_enable: Axle Weight 1st
axle_weight_2nd_enable: Axle Weight 2nd
axle_weight_3rd_enable: Axle Weight 3rd
axle_weight_4th_enable: Axle Weight 4th
battery_current_enable: Battery Current
battery_voltage_enable: Battery Voltage
charging_status_enable: Charging Status
retarder_status_enable: Retarder Status
total_fuel_used_enable: Total Fuel Used
charging_current_enable: Charging Current
charging_voltage_enable: Charging Voltage
engine_oil_level_enable: Engine Oil Level
fuel_consumption_enable: Fuel Consumption
nmea2000_heading_enable: Heading
seat_belt_status_enable: Seat Belt Status
ultima_f2_change_enable: Ultima F2 Change
brake_fluid_level_enable: Brake Fluid Level
cabin_temperature_enable: Cabin Temperature
cargo_temperature_enable: Cargo Temperature
motor_temperature_enable: Motor Temperature
adblue_temperature_enable: AdBlue Temperature
alternator_voltage_enable: Alternator Voltage
battery_voltage_ev_enable: Battery Voltage (EV)
driver1_break_time_enable: Cumulative Break Time
driver2_break_time_enable: Cumulative Break Time
tacho_system_event_enable: System Event
total_driving_time_enable: Total Driving Time
total_engine_hours_enable: Total Engine Hours
ambient_temperature_enable: Ambient Temperature
battery_temperature_enable: Battery Temperature
driver1_card_change_enable: Driver 1 Card Change
driver2_card_change_enable: Driver 2 Card Change
engine_oil_pressure_enable: Engine Oil Pressure
nmea2000_wind_angle_enable: Wind Angle
nmea2000_wind_speed_enable: Wind Speed
out_of_scope_change_enable: Out of Scope Change
battery_charge_level_enable: Battery Charge Level (EV)
brake_pedal_position_enable: Brake Pedal Position
nmea2000_speed_water_enable: Speed Through Water
tacho_vehicle_motion_enable: Vehicle Motion
total_idle_fuel_used_enable: Total Idle Fuel Used
clutch_pedal_position_enable: Clutch Pedal Position
cruise_control_status_enable: Cruise Control Status
driver1_status_change_enable: Driver 1 Status Change
driver2_status_change_enable: Driver 2 Status Change
driver1_min_daily_rest_enable: Minimum Daily Rest
driver2_min_daily_rest_enable: Minimum Daily Rest
engine_oil_temperature_enable: Engine Oil Temperature
total_engine_idle_time_enable: Total Engine Idle Time
driver1_last_daily_rest_enable: End of Last Daily Rest Period
driver1_min_weekly_rest_enable: Minimum Weekly Rest
driver2_last_daily_rest_enable: End of Last Daily Rest Period
driver2_min_weekly_rest_enable: Minimum Weekly Rest
engine_all_starts_count_enable: Engine All Starts Count
tacho_vehicle_direction_enable: Vehicle Direction
tacho_vehicle_overspeed_enable: Vehicle Overspeed
driver1_last_weekly_rest_enable: End of Last Weekly Rest Period
driver1_max_daily_period_enable: Maximum Daily Period
driver1_time_until_break_enable: Time Until Next Break
driver2_last_weekly_rest_enable: End of Last Weekly Rest Period
driver2_max_daily_period_enable: Maximum Daily Period
driver2_time_until_break_enable: Time Until Next Break
engine_cold_starts_count_enable: Engine Cold Starts Count
driver1_activity_duration_enable: Current Activity Duration
driver1_max_daily_driving_enable: Maximum Daily Driving Time
driver2_activity_duration_enable: Current Activity Duration
driver2_max_daily_driving_enable: Maximum Daily Driving Time
tacho_driver_slots_status_enable: Driver Slots Status
tacho_specific_conditions_enable: Specific Conditions
accelerator_pedal_pressure_enable: Accelerator Pedal Pressure
driver1_continuous_driving_enable: Continuous Driving Time
driver1_daily_driving_time_enable: Current Daily Driving Time
driver1_reduced_daily_rest_enable: Reduced Daily Rest Periods
driver1_time_until_driving_enable: Time Until Next Driving
driver1_uninterrupted_rest_enable: Cumulative Uninterrupted Rest
driver2_continuous_driving_enable: Continuous Driving Time
driver2_daily_driving_time_enable: Current Daily Driving Time
driver2_reduced_daily_rest_enable: Reduced Daily Rest Periods
driver2_time_until_driving_enable: Time Until Next Driving
driver2_uninterrupted_rest_enable: Cumulative Uninterrupted Rest
engine_coolant_temperature_enable: Engine Coolant Temperature
tacho_driver_card_presence_enable: Driver Card Presence
tacho_driver_working_state_enable: Driver Working State
tacho_handling_information_enable: Handling Information
can_info_mask3_co2_emission_enable: Total CO2 Emission
driver1_accumulated_driving_enable: Accumulated Driving Time
driver1_next_break_duration_enable: Next Break Duration
driver1_weekly_driving_time_enable: Current Weekly Driving Time
driver2_accumulated_driving_enable: Accumulated Driving Time
driver2_next_break_duration_enable: Next Break Duration
driver2_weekly_driving_time_enable: Current Weekly Driving Time
total_engine_overspeed_time_enable: Total Engine Overspeed Time
can_info_mask3_fuel_used_pto_enable: Total Fuel Used With PTO
driver1_remaining_drive_time_enable: Remaining Current Drive Time
driver2_remaining_drive_time_enable: Remaining Current Drive Time
total_vehicle_overspeed_time_enable: Total Vehicle Overspeed Time
can_info_mask3_pto_usage_time_enable: Total PTO Usage Time
driver1_next_driving_duration_enable: Next Driving Duration
driver1_time_until_daily_rest_enable: Time Until Daily Rest
driver2_next_driving_duration_enable: Next Driving Duration
driver2_time_until_daily_rest_enable: Time Until Daily Rest
driver1_daily_driving_exceeded_enable: Daily Driving Times Exceeded
driver1_last_week_compensation_enable: Last Week Compensation
driver1_time_until_weekly_rest_enable: Time Until Weekly Rest
driver2_daily_driving_exceeded_enable: Daily Driving Times Exceeded
driver2_last_week_compensation_enable: Last Week Compensation
driver2_time_until_weekly_rest_enable: Time Until Weekly Rest
total_engine_cold_running_time_enable: Total Engine Cold Running Time
transmission_fluid_temperature_enable: Transmission Fluid Temperature
driver1_current_break_remaining_enable: Current Break Remaining
driver1_second_last_weekly_rest_enable: End of Second Last Weekly Rest Period
driver1_shift_driving_remaining_enable: Shift Driving Remaining
driver2_current_break_remaining_enable: Current Break Remaining
driver2_second_last_weekly_rest_enable: End of Second Last Weekly Rest Period
driver2_shift_driving_remaining_enable: Shift Driving Remaining
engine_starts_by_ignition_count_enable: Engine Starts by Ignition Count
driver1_weekly_driving_remaining_enable: Weekly Driving Remaining
driver2_weekly_driving_remaining_enable: Weekly Driving Remaining
tacho_driver_time_related_status_enable: Driver Time Related Status
can_info_mask3_retarder_usage_time_enable: Total Retarder Usage Time
handbrake_applies_during_ride_count_enable: Handbrake Applies During Ride Count
driver1_week_before_last_compensation_enable: Week Before Last Compensation
driver2_week_before_last_compensation_enable: Week Before Last Compensation
driver1_second_week_before_compensation_enable: 2nd Week Before Compensation
driver2_second_week_before_compensation_enable: 2nd Week Before Compensation
CAN Alarm Setting
cas
hood_alarm: Hood Alarm
doors_alarm: Doors Alarm
trunk_alarm: Trunk Alarm
debounce_time: Debounce Time
driver_door_alarm: Driver Door Alarm
central_lock_alarm: Central Lock Alarm
passenger_door_alarm: Passenger Door Alarm
rear_left_door_alarm: Rear Left Door Alarm
rear_right_door_alarm: Rear Right Door Alarm
Clear Car Model/ID
clear_car_model
Clear the current car model/ID configuration
CAN Module Setting
cms
accel_time: Rapid Acceleration Time
brake_time: Rapid Braking Time
accel_speed: Rapid Acceleration Speed
brake_speed: Rapid Braking Speed
disable_can1_tx: Disable CAN1 Tx
disable_can2_tx: Disable CAN2 Tx
over_speed_limit: Over Speed Limit
over_engine_speed_limit: Over Engine Speed Limit
lower_engine_speed_limit: Lower Engine Speed Limit
Delete Buffer
delete_buffer
Delete message buffer in the device
Software Watchdog
dog
Reboot the device in a time based manner
time: Time
FTP Server
ftp
Configure the FTP server information as to where and how to upload files
full_name: Full Name
user_name: User Name
server_port: Server Port
transfer_mode: Transfer Mode
login_password: Login Password
server_address: Server Address
prefix_file_name: Prefix File Name
Global Configuration Settings
gcs
led_mode: LED Mode
agps_mode: AGPS Mode
odo_enable: Odometer Enable
hdop_enable: HDOP
new_password: New Password
speed_enable: Speed
azimuth_enable: Azimuth
id_data_enable: ID Data
altitude_enable: Altitude
latitude_enable: Latitude
nmea2000_enable: NMEA2000 Information
utc_time_enable: UTC Time
longitude_enable: Longitude
crash_info_enable: Crash Info
event_data_enable: Event Data
geo_status_enable: GEO Status
gnss_working_mode: GNSS Working Mode
hour_meter_enable: Hour Meter Enable
main_power_enable: Main Power
power_saving_mode: Power Saving Mode
special_car_enable: Special Car Information
analog_input_enable: Analog Input
electric_can_enable: Electric CAN Information
mileage_info_enable: Mileage Info
network_type_enable: Network Type Information
odo_initial_mileage: Initial Mileage
tacho_common_enable: Tachograph Common Event Information
digital_input_enable: Digital Input
tacho_driver1_enable: Tachograph Driver1 Working Time
tacho_driver2_enable: Tachograph Driver2 Working Time
digital_output_enable: Digital Output
low_battery_threshold: Low Battery Threshold
onewire_sensor_enable: 1-wire Sensor
gnss_satellites_enable: GNSS Satellites Number
ignition_motion_enable: Ignition & Motion State
motor_can_mask1_enable: Motor CAN Information Mask1
motor_can_mask2_enable: Motor CAN Information Mask2
axis_calibration_enable: 3-Axis Self-Calibration Info
cell_information_enable: Cell Information
gnss_fixing_type_enable: GNSS Fixing Type
gnss_information_enable: GNSS Information
hour_meter_count_enable: Hour Meter Count
initial_hour_meter_count: Initial Hour Meter Count
low_main_power_threshold: Low Main Power Threshold
satellites_number_enable: Satellites Number
battery_information_enable: Battery Information
upgrade_information_enable: Upgrade Information
Get CAN Information
get_can_info
Get CAN information via CAN message of +RPT
Get CAN Version Information
get_can_version
can_serial_number: CAN Serial Number
can_version_number: CAN Version Number
Ignition Settings
ign
voltage_offset: Voltage Offset
output1_restrict: Output1 Ignition-On Restrict
ign_debounce_time: IGN Debounce Time
vgf_rest_duration: VGF Rest Duration
wire_ignition_mode: Wire Ignition Mode
ignition_on_voltage: Ignition On Voltage
vgn_motion_duration: VGN Motion Duration
ignition_on_debounce: Ignition On Debounce
ignition_off_debounce: Ignition Off Debounce
virtual_ignition_mode: Virtual Ignition Mode
Jamming Alarm Setting
jam
rsrp_lte: RSRP (LTE)
rsrq_lte: RSRQ (LTE)
rssi_gsm: RSSI (GSM)
rssi_lte: RSSI (LTE)
sinr_gsm: SINR (GSM)
minch_gsm: MINCH (GSM)
quit_jamming_duration: Quit Jamming Duration
enter_jamming_duration: Enter Jamming Duration
Movement Alarm
mov
motion_duration: Motion Duration
motion_threshold: Motion Threshold
stillness_duration: Stillness Duration
motion_event_report: Motion Event Report
Network Information Setting
nis
scan_mode: Network scan mode
Query Network Information
query_network
Get current network status information
Query Firmware Version
query_version
Get current firmware version information
Read Current Car Model
read_car_model
Read the current car model/ID from the device
Reboot Device
Restart the device
Regular Report Setting
rrs
mileage: Mileage
corner_angle: Corner Angle
discard_no_fix: Discard No Fix
igf_send_interval: IGF Send Interval
ign_send_interval: IGN Send Interval
ign_gnss_fixing_interval: IGN GNSS Fixing Interval
Set Car Mode
set_car_mode
Set the car mode for CAN operations
mode: Car Mode
Server Information Settings
sis
tls_enable: TLS Enable
buffer_mode: Buffer Mode
sack_enable: SACK Enable
tls_verify_mode: TLS Verification Mode
heartbeat_interval: Heartbeat Interval
Start Auto-Synchronization
start_auto_sync
Start the CAN auto-synchronization process to detect car model
Cancel tacho file request
tacho_cancel_process
Cancel the ongoing tachograph DDD file request
Tachograph Common Operation
tco
tacho: Sub Command
BLE Transparent Transmission
trb
Send data from the server to the BLE master connected to the tracker over BLE (one-shot action)
data: Data
command_type: Command Type
Update CAN Chip Firmware
update_can_firmware
Update the CAN chip firmware
url: Firmware URL
Update Main Firmware
update_main_firmware
Update the main firmware of the device
url: Firmware URL
Upload files to FTP
upload_files_ftp
Request the device to upload a file directly to an FTP server. The FTP server must be configured first via the "FTP Server" setting on the "Connectivity" tab.
tacho_ftp: Report Mode
1-Wire Application Setting
was
temp: Temperature Timer Enable
ibutton_timer: iButton Timer
onewire_data_mask: 1-Wire Data Mask
text: Text payload
Toggle Digital output
{"text":"AT@OUT=at,1,0,2,0,0001#"}
Get Server Information Settings
{"text":"AT@SIS?at,,0001#"}
Request tachograph file
request_tachograph_file
