Assistant Telematics AVT50
The AVT50 is a versatile vehicle GPS tracker with LTE Cat 1 and 2G fallback. It features a robust IP67 waterproof design, 3-axis accelerometer, BLE 5.3, and a 250mAh Li-Polymer battery, ensuring reliable operation between -30℃ and +75℃. Supporting GPS, BDS, GLONASS, Galileo, QZSS, and SBAS systems, it offers less than 2.0 m positioning accuracy and quick start times with tracking sensitivity of -160 dBm. The device is powered by a wide voltage range of 7V to 90V DC, has a compact form factor of 100x45x18mm, and includes various input/output options.
Parameters (317)
Settings (15)
Flespi parses telemetry data from your Assistant Telematics AVT50 into a standardized JSON and lets you send commands to Assistant Telematics AVT50 via API.
    "device.type.id": "Assistant Telematics AVT50",
    "protocol.id": "assistant-telematics"
How to send commands to Assistant Telematics AVT50?
Packet head RPT
Packet head DFI,
Packet head RPT
battery.charging.state
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head DFI
beidou.visible.satellites
Packet head RPT
Packet head RPT
Event type 44: BLE Slave Connect Event,
Packet head RPT
ble.dout
BLE digital output state
Packet head RPT
Packet head DFI,
Packet head VER
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
can.carbon.dioxide.exhausted
Packet head RPT
Event type 45: CANBUS Info Alarm Event,
Packet head RPT
Packet head RPT
Packet head CMI,
Packet head DFI
can.controller.hardware.version
Controller hardware version read from CAN
Packet head DFI
Packet head DFI
Packet head DFI
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
can.driver.door.status
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head RPT
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
can.idle.fuel.consumed
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
can.passenger.door.status
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
can.pto.run.time
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
can.retarder.time
Total retarder usage time read from CAN
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
can.tpms.indicator.status
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head RPT
can.vessel.direction
Vessel compass heading read from CAN bus (NMEA2000)
Packet head RPT
can.water.depth
Water depth read from CAN bus
Packet head RPT
can.water.speed
Speed through water read from CAN bus (NMEA2000)
Packet head RPT
Packet head RPT
can.wind.direction
rad
Wind direction read from CAN bus bus
Packet head RPT
can.wind.speed
m/s
Wind speed read from CAN bus
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head DFI,
Packet head VER
device.illuminance
Packet head RPT
Packet head RPT
Packet head DFI,
Packet head RPT
distance.alarm
Distance alarm detected
Packet head RPT
Packet head RPT
Packet head DFI,
Packet head RPT
ecl.trigger.bitmask
ECL (Event Driver Command List) trigger mask - bitmask of trigger conditions that fired the ECL alarm
Packet head RPT
Packet head RPT
Packet head RPT
Event Type,
Packet head RPT
event.id
Event type 43: ECL Trigger alarm event,
Packet head RPT
event.name
Protocol-specific event name
Packet head RPT
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head RPT
galileo.position.satellites
Packet head DFI
galileo.visible.satellites
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
glonass.visible.satellites
Packet head RPT
Packet head DFI
Packet head DFI
gps.visible.satellites
Packet head RPT
Packet head QNI,
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head DFI,
Packet head QNI,
Packet head RPT
gsm.network.type.enum
Packet head DFI,
Packet head QNI,
Packet head RPT
Packet head QNI,
Packet head RPT
Packet head DFI
Packet head QNI
Packet head QNI
Packet head QNI
Packet head DFI,
Packet head VER
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
main.power.low.status
Main power low status
Packet head RPT
message.seqnum
Packet head GAV,
Packet head GSV,
Packet head LSV,
Packet head RPT
Packet head VER
Packet head RPT
network.ip.address
IP address of the network
Packet head QNI
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head BMR
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head GAV,
Packet head GSV,
Packet head LSV
Packet head DFI,
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head RPT
Packet head RPT
Packet head GAV,
Packet head GSV,
Packet head HBD,
Packet head LSV,
Packet head RPT,
Packet head VER
Packet head RPT
rf433.channel
RF433 channel number (0-19 maps to 433.0-434.9 MHz)
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head GAV,
Packet head GSV,
Packet head LSV
Packet head RPT
Packet head RPT
Packet head RPT
sensor.x.acceleration
Acceleration sensor X-axis value
Packet head RPT
sensor.y.acceleration
Acceleration sensor Y-axis value
Packet head RPT
sensor.z.acceleration
Acceleration sensor Z-axis value
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
tacho.card.reader.status
Tacho card reader state
Packet head DFI
Packet head DFI,
Packet head RPT
tacho.communication.state
Tacho communication state
Packet head DFI,
Packet head RPT
tacho.communication.state.enum
Tacho communication state, 0 - no communication, 1 - online, 2 - error, 3 - not supported
Packet head DFI,
Packet head RPT
tacho.download.state
Tacho remote DDD download state
Packet head DFI,
Packet head RPT
tacho.download.state.enum
Tacho remote DDD download state, 0 - disabled, 1 - enabled, 2 - error, 3 - not supported
Packet head DFI,
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
tacho.driving.direction
Packet head DFI,
Packet head RPT
Packet head RPT
tacho.file.state
Tachograph file state flags description
Packet head RPT
Packet head RPT
tacho.kline.bus.state
Tacho D8/K-Line bus state
Packet head DFI,
Packet head RPT
tacho.kline.bus.state.enum
Tacho D8/K-Line bus state, 0 - sleep, 1 - active, 2 - error, 3 - not used
Packet head DFI,
Packet head RPT
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head RPT
Packet head RPT
tacho.state
Tachograph state flags description
Packet head RPT
Packet head RPT
tacho.state.error
Tachograph state error description
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
tilt.event
Tilt event
Packet head RPT
Packet head GAV,
Packet head GSV,
Packet head LDP,
Packet head LSV,
Packet head RPT
Packet head GAV,
Packet head GSV,
Packet head LSV,
Packet head RPT
tire
Axle and tire index
Packet head RPT
Packet head RPT
Packet head RPT
tire.underpressure.status
Tire underpressure
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head RPT
Packet head RPT
upgrade.status.name
Upgrade status
Packet head RPT
Packet head RPT
Packet head CMI,
Packet head DFI,
Packet head RPT
Packet head CMI,
Packet head DFI
Packet head RPT
Packet head DFI,
Packet head RPT
Packet head RPT
Packet head RPT
Packet head RPT
Alarm Output Setting
aos
output_id: Output ID
toggle_times: Toggle Times
output_status: Output Status
alarm_trigger_mask: Alarm OUT1 Trigger Mask
Crash Detection Setting
cra
x_axis_threshold: X Axis Threshold
y_axis_threshold: Y Axis Threshold
z_axis_threshold: Z Axis Threshold
Data Acquisition Mode
dam
input_mode: Input Mode
debounce_time: Debounce Time
validity_time: Validity Time
delta_ais_duration: Delta AIS Duration
delta_ais_threshold: Delta AIS Threshold
Delete Buffer
delete_buffer
Delete message buffer in the device
Global Configuration Settings
gcs
led_mode: LED Mode
agps_mode: AGPS Mode
odo_enable: Odometer Enable
hdop_enable: HDOP
gnss_timeout: GNSS Timeout
new_password: New Password
speed_enable: Speed
charging_mode: Charging Mode
azimuth_enable: Azimuth
altitude_enable: Altitude
latitude_enable: Latitude
utc_time_enable: UTC Time
longitude_enable: Longitude
event_data_enable: Event Data
geo_status_enable: GEO Status
gnss_working_mode: GNSS Working Mode
hour_meter_enable: Hour Meter Enable
main_power_enable: Main Power
power_saving_mode: Power Saving Mode
analog_input_enable: Analog Input
mileage_info_enable: Mileage Info
network_type_enable: Network Type Information
odo_initial_mileage: Initial Mileage
digital_input_enable: Digital Input
digital_output_enable: Digital Output
low_battery_threshold: Low Battery Threshold
ignition_motion_enable: Ignition & Motion State
cell_information_enable: Cell Information
gnss_fixing_type_enable: GNSS Fixing Type
gnss_information_enable: GNSS Information
hour_meter_count_enable: Hour meter count mask
initial_hour_meter_count: Initial Hour Meter Count
low_main_power_threshold: Low Main Power Threshold
satellites_number_enable: Satellites Number
battery_information_enable: Battery Information
upgrade_information_enable: Upgrade Information
Harsh Behavior Setting
hbs
braking_duration: Braking Duration
braking_threshold: Braking Threshold
cornering_duration: Cornering Duration
cornering_threshold: Cornering Threshold
acceleration_duration: Acceleration Duration
acceleration_threshold: Acceleration Threshold
Ignition Settings
ign
voltage_offset: Voltage Offset
ign_debounce_time: IGN Debounce Time
vgf_rest_duration: VGF Rest Duration
wire_ignition_mode: Wire Ignition Mode
ignition_on_voltage: Ignition On Voltage
vgn_motion_duration: VGN Motion Duration
ignition_on_debounce: Ignition On Debounce
ignition_off_debounce: Ignition Off Debounce
virtual_ignition_mode: Virtual Ignition Mode
Movement Alarm
mov
motion_duration: Motion Duration
motion_threshold: Motion Threshold
stillness_duration: Stillness Duration
Network Information Setting
nis
scan_mode: Network scan mode
Query Network Information
query_network
Get current network status information
Query Firmware Version
query_version
Get current firmware version information
Reboot Device
Restart the device
Regular Report Setting
rrs
corner_angle: Corner Angle
discard_no_fix: Discard No Fix
igf_send_interval: IGF Send Interval
ign_send_interval: IGN Send Interval
ign_gnss_fixing_interval: IGN GNSS Fixing Interval
Server Information Settings
sis
tls_enable: TLS Enable
buffer_mode: Buffer Mode
sack_enable: SACK Enable
server_port: Server Port
server_address: Server Address
tls_verify_mode: TLS Verification Mode
heartbeat_interval: Heartbeat Interval
Speed Setting
spd
speed_threshold: Speed Threshold
over_speed_duration: Over Speed Duration
text: Text payload
Toggle Digital output
{"text":"AT@OUT=at,1,0,2,0,0001#"}
Get Server Information Settings
{"text":"AT@SIS?at,,0001#"}
