Wialon-ips protocol
Universal protocol by Gurtam designed for tracker manufacturers.
flespi parses the Wialon-ips protocol messages into a JSON object with the fields listed below in the Parameters tab.
Wialon IPS communication protocol was developed by Gurtam for personal and vehicle GPS/GLONASS trackers that send data to satellite monitoring system server over TCP and UDP.
Wialon IPS protocol is freely distributed under GNU FDL and can be used by manufacturers of GPS and GLONASS equipment as the main protocol for data transmission between GPS/GLONASS trackers and communication server of satellite monitoring system.
The flespi platform can work over both Wialon IPS v1.1 and 2.0.
Note, it is not compatible with Wialon Retranslator and Wialon Combine protocols.
field 'accelerometer'
absolute.deceleration
field 'accel_res'
#B,
#D
field 'SOS'
field 'battery'
field 'pwr_int'
field 'axis_weight'
field 'cool_temp'
field 'engine_temp'
field 'fuel_volume'
#B,
#D
#B,
#D
#M
field 'engine operation',
field 'ign'
field 'engine_hours'
engine.oil.pressure
Engine oil pressure
field 'oil_pressure'
field 'engine rpm',
field 'engine_rpm'
field 'pwr_ext'
field 'fuel_consumption'
field 'fuel_level'
field 'fuel level'
field 'cell_id',
field 'gsm_cell'
field 'lac'
field 'mcc'
field 'mnc'
field 'hw_cfg_in_roaming'
field 'gsm'
#B,
#D,
field 'avl_driver',
field 'ibutton'
#B,
#D,
#SD
#B,
#D,
#SD
#B,
#D,
field 'hdop'
#B,
#D,
#SD
#B,
#D,
#SD
#B,
#D,
#SD
#B,
#D,
#SD
field 'hw_cfg_protocol_version'
field 'sf_ver'
field 'taho_speed'
#B,
#D,
#SD
touch.memory.id
Touch Memory Key ID
field 'touch_key'
field 'mileage'
field 'accel_x'
field 'accel_y'
field 'accel_z'
Custom message command
The command is used to send custom messages to the device. It allows to implement additional features necessary for the controller. is added automatically
message: Text of the message
Send custom message command
{"message":"Text of the message"}
Text message
text_msg
Send text message to device
message: Text message content
Send text message
{"message":"this is message text"}
