GPS Tag
GPS Tag is a native iOS/Android mobile app that turns your smartphone, tablet or another mobile device into a GPS tracker compatible with Wialon platform. The application suits many personal tracking applications including children and elderly tracking, couriers monitoring, field sales agents and taxi drivers monitoring.
Parameters (55)
GPS Tag
Flespi parses telemetry data from your GPS Tag into a standardized JSON and lets you send commands to GPS Tag via API.
    "device.type.id": "GPS Tag",
    "protocol.id": "wialon-ips"
How to send commands to GPS Tag?
field 'accelerometer'
absolute.deceleration
field 'accel_res'
#B,
#D
field 'SOS'
field 'battery'
field 'pwr_int'
field 'axis_weight'
field 'cool_temp'
field 'engine_temp'
field 'fuel_volume'
#B,
#D
#B,
#D
#M
field 'engine operation',
field 'ign'
field 'engine_hours'
engine.oil.pressure
Engine oil pressure
field 'oil_pressure'
field 'engine rpm',
field 'engine_rpm'
field 'pwr_ext'
field 'fuel_consumption'
field 'fuel_level'
field 'fuel level'
field 'cell_id',
field 'gsm_cell'
field 'lac'
field 'mcc'
field 'mnc'
field 'hw_cfg_in_roaming'
field 'gsm'
#B,
#D,
field 'avl_driver',
field 'ibutton'
#B,
#D,
#SD
#B,
#D,
#SD
#B,
#D,
field 'hdop'
#B,
#D,
#SD
#B,
#D,
#SD
#B,
#D,
#SD
#B,
#D,
#SD
field 'hw_cfg_protocol_version'
field 'sf_ver'
field 'taho_speed'
#B,
#D,
#SD
touch.memory.id
Touch Memory Key ID
field 'touch_key'
field 'mileage'
field 'accel_x'
field 'accel_y'
field 'accel_z'
Send custom message command
custom_command
text: Command text
Send Message
message
text: Text
The command is used to send custom messages to the device. It allows to implement additional features necessary for the controller. is added automatically
message: Text of the message
{"message":"Text of the message"}
Text message
text_msg
Send text message to device
message: Text message content
Send text message
{"message":"this is message text"}
