Tacho Bridge App
Tacho Bridge App is an open-source application for Windows, Mac OS or Linux designed to provide remote authentication of a tracker and tachograph via the company card.
Application is installed on the computer (tacho card hotels supported) and provides an interface between cards inserted into smart card reader and flespi. Whenever the tracker needs to authenticate the tachograph using company card the application will provide such functionality.
Tacho Bridge Application which is installed on user's computer or server is itself represented as Tacho Bridge App device in flespi while each card connected to it should be registered as Tacho Bridge Card device.
Check setup guide for more information.
Parameters (11)
Settings (4)
Tacho Bridge App
Flespi parses telemetry data from your Tacho Bridge App into a standardized JSON and lets you send commands to Tacho Bridge App via API.
    "device.type.id": "Tacho Bridge App",
    "protocol.id": "tacho-bridge"
How to send commands to Tacho Bridge App?
Application Information
app_info
Tacho Bridge App instance information, reported by the application on connection. Read-only.
os: Operating system
arch: CPU architecture
version: Application version
os_release: Operating system release
Authentication
authentication
MQTT credentials the application presents on every connection it opens (the application itself and its cards). The server checks them against the 'credentials' username and password of the channel configuration, so set them there first: without explicit values the setting pushes the channel pair.
credentials: Enable authentication
Extended debug log
debug_log
Extended application debug log: raises the verbosity of the application log for a window of time, so the next 'Fetch application logs' command carries the details the server-side traffic dump does not have. The log stays on the application side. The state is also reported by the application on every connection.
window: Enable extended debug log
Server address
Address of the MQTT server the application connects to with every connection it opens (the application itself and its cards), reported by the application on connection. Changing it moves the application to another server: the result comes back on the current connection, then the application reconnects everything to the new address.
fetch_logs
Fetch the application log file for the given period; the zipped log is attached to the command result
period: Log period
