CalAmp LMU-4220
CalAmp LMU-4220 product has the features, expandability, and flexibility with the intelligence to meet all customer’s needs in fleet management. The LMU-4220 offers a full set of features, comprehensive I/O system and expandable accessories that make it an industry leading value proposition. The LMU-4220 expandability and flexibility lowers the cost of delivering, supporting, and growing fleet management solutions.
Parameters (50)
Settings (1)
CalAmp LMU-4220
Flespi parses telemetry data from your CalAmp LMU-4220 into a standardized JSON and lets you send commands to CalAmp LMU-4220 via API.
    "device.type.id": "CalAmp LMU-4220",
    "protocol.id": "calamp"
How to send commands to CalAmp LMU-4220?
accumulator
Message Type 10,
Message Type 12,
Message Type 14,
Message Type 2,
Message Type 5,
Message Type 8,
Message Type 9
accumulator.exceed.threshold
Message Type 10,
Message Type 12,
Message Type 14,
Message Type 2,
Message Type 5,
Message Type 8,
Message Type 9
Message Type 12,
Message Type 14,
Message Type 5
Message Type 10,
Message Type 12,
Message Type 14,
Message Type 2,
Message Type 4,
Message Type 5,
Message Type 8,
Message Type 9
Message Type 12,
Message Type 14,
Message Type 5
Message Type 10,
Message Type 14,
Message Type 2,
Message Type 4,
Message Type 5,
Message Type 8,
Message Type 9
esn
Message Type 10,
Message Type 2
geofence.status.bitmask
Message Type 12,
Message Type 14,
Message Type 5
Message Type 10,
Message Type 2
Message Type 2
Message Type 2
Message Type 2
Message Type 2
Message Type 10,
Message Type 14,
Message Type 2,
Message Type 4,
Message Type 5,
Message Type 8,
Message Type 9
Message Type 3
Message Type 2
message.type.enum
Message Type
Message Type 14,
Message Type 2,
Message Type 4,
Message Type 5,
Message Type 8,
Message Type 9
Message Type 11,
Message Type 4,
Message Type 9
peg.bitmask
Message Type 12,
Message Type 14,
Message Type 5
position.2dfix.status
Message Type 2
Message Type 2
position.corrected.status
Message Type 2
Message Type 10,
Message Type 2
Message Type 14,
Message Type 2,
Message Type 4,
Message Type 5,
Message Type 8,
Message Type 9
position.last.known.status
Message Type 2
Message Type 10,
Message Type 2
Message Type 10,
Message Type 2
position.predicted.status
Message Type 2
Message Type 10,
Message Type 2
Message Type 10,
Message Type 2
Message Type 2
Message Type 10,
Message Type 2
Message Type 10,
Message Type 11,
Message Type 12,
Message Type 14,
Message Type 2,
Message Type 4,
Message Type 5,
Message Type 8,
Message Type 9
Message Type 10,
Message Type 11,
Message Type 12,
Message Type 14,
Message Type 2,
Message Type 4,
Message Type 5,
Message Type 8,
Message Type 9
user.message.id
User message ID
Message Type 11,
Message Type 4,
Message Type 9
user.message.route
User message route
Message Type 11,
Message Type 4,
Message Type 9
Message Type 12,
Message Type 14,
Message Type 5
Generic device information.
AT Command
at
Query Current IP Address
{"payload":"$APP ADDR?"}
Query Current Output States
{"payload":"$APP OUTPUT?"}
message_type: Message Type
Query position type & data
