CalAmp LMU-4230
The LMU-4230 includes a range of wireless and peripheral connectivity options and is equipped with CalAmp’s next generation vehicle interface technologies for both light and heavy duty vehicle telematics including hybrids, trucks and vans.
Parameters (50)
Settings (1)
CalAmp LMU-4230
Flespi parses telemetry data from your CalAmp LMU-4230 into a standardized JSON and lets you send commands to CalAmp LMU-4230 via API.
    "device.type.id": "CalAmp LMU-4230",
    "protocol.id": "calamp"
How to send commands to CalAmp LMU-4230?
accumulator
Message Type 10,
Message Type 12,
Message Type 14,
Message Type 2,
Message Type 5,
Message Type 8,
Message Type 9
accumulator.exceed.threshold
Message Type 10,
Message Type 12,
Message Type 14,
Message Type 2,
Message Type 5,
Message Type 8,
Message Type 9
Message Type 12,
Message Type 14,
Message Type 5
Message Type 10,
Message Type 12,
Message Type 14,
Message Type 2,
Message Type 4,
Message Type 5,
Message Type 8,
Message Type 9
Message Type 12,
Message Type 14,
Message Type 5
Message Type 10,
Message Type 14,
Message Type 2,
Message Type 4,
Message Type 5,
Message Type 8,
Message Type 9
esn
Message Type 10,
Message Type 2
geofence.status.bitmask
Message Type 12,
Message Type 14,
Message Type 5
Message Type 10,
Message Type 2
Message Type 2
Message Type 2
Message Type 2
Message Type 2
Message Type 10,
Message Type 14,
Message Type 2,
Message Type 4,
Message Type 5,
Message Type 8,
Message Type 9
Message Type 3
Message Type 2
message.type.enum
Message Type
Message Type 14,
Message Type 2,
Message Type 4,
Message Type 5,
Message Type 8,
Message Type 9
Message Type 11,
Message Type 4,
Message Type 9
peg.bitmask
Message Type 12,
Message Type 14,
Message Type 5
position.2dfix.status
Message Type 2
Message Type 2
position.corrected.status
Message Type 2
Message Type 10,
Message Type 2
Message Type 14,
Message Type 2,
Message Type 4,
Message Type 5,
Message Type 8,
Message Type 9
position.last.known.status
Message Type 2
Message Type 10,
Message Type 2
Message Type 10,
Message Type 2
position.predicted.status
Message Type 2
Message Type 10,
Message Type 2
Message Type 10,
Message Type 2
Message Type 2
Message Type 10,
Message Type 2
Message Type 10,
Message Type 11,
Message Type 12,
Message Type 14,
Message Type 2,
Message Type 4,
Message Type 5,
Message Type 8,
Message Type 9
Message Type 10,
Message Type 11,
Message Type 12,
Message Type 14,
Message Type 2,
Message Type 4,
Message Type 5,
Message Type 8,
Message Type 9
user.message.id
User message ID
Message Type 11,
Message Type 4,
Message Type 9
user.message.route
User message route
Message Type 11,
Message Type 4,
Message Type 9
Message Type 12,
Message Type 14,
Message Type 5
Generic device information.
AT Command
at
Query Current IP Address
{"payload":"$APP ADDR?"}
Query Current Output States
{"payload":"$APP OUTPUT?"}
message_type: Message Type
Query position type & data
