Jimi IoT (Concox) AT4
Concox AT4 is a rugged GPS tracking unit with a 10,000mAh battery, a powerful magnetic mount, and a built-in MIC for voice monitoring. The device features an intelligent power management system, a tamper alert, and more. The casing complies with IPx5 rating making it resistant to water spray.
Parameters (372)
Settings (24)
Flespi parses telemetry data from your Jimi IoT (Concox) AT4 into a standardized JSON and lets you send commands to Jimi IoT (Concox) AT4 via API.
    "device.type.id": "Jimi IoT (Concox) AT4",
How to send commands to Jimi IoT (Concox) AT4?
Message ID 0x0010
Message ID 0x0010
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010
Message ID 0x0010
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010,
Message ID 0x0010
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010,
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010,
Message ID 0x0010,
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010,
Message ID 0x0010,
Protocol Number 0x39
Protocol Number 0x15
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010,
ACC Report
acc_report
ACC Change Report Setup
enable: Enable ACC Report
Analog Input Data Interval
analog_interval
Analog Input Data Upload Interval
ad_upload: Enable Upload of Analog Data
Angle Report
angle_report
Angle Change Report Setup
angle_rep: Enable Angle Report
External Battery Alarm
bat_alarm
External Battery Alarm Setup
battery: Enable Alarm
GPS Blind Alarm
blind_alarm
GSP Blind Area Alarm Setup
blind: Enable Alarm
Center Number
center_number
phone: Center Number
Delayed Defense
defense
Delayed Defense Setup
delay: Delayed Defense
Door Alarm Condition
door
Door Alarm Condition Setting: Positive or Negative
mode: Alarm Condition
Side Door Alarm
door_alarm
Door Alarm Setup
door: Enable Alarm
Find
find
Find vehicle by triggering light and buzzer
Geofence Alarm
geofence_alarm
Geofence Alarm Setup
fence: Enable Alarm
GPS Data Upload
gps_data_upload
GPS Data Upload Setup
mode: GPS Data Upload Mode
Heartbeat Interval
hbt_interval
hbt_on: ACC ON Interval
hbt_off: ACC OFF Interval
LED Sleep Mode
led_sleep
LED Sleep Mode Setup
enable: Enable LED Sleep Mode
Displacement Alarm
move_alarm
Displacement Alarm Setup
move: Enable Alarm
Configure APN parameters
Mileage Statistics
Mileage Statistics Function
odometer: Mileage Statistics
Overspeeding Alarm
overspeed_alarm
Overspeeding Alarm Setup
overspeed: Enable Alarm
Restart Device
Server Setup
comm: Communication Mode
mode: Host Mode
SOS Alarm
sos_alarm
SOS Alarm Setup
sos: Enable Alarm
SOS Numbers
sos_numbers
SOS Phone Numbers Setup
delete: Delete Numbers
phone1: First Number
phone2: Second Number
phone3: Third Number
timezone
Time Zone Setup
Vibration Alarm
vibr_alarm
Vibration Alarm Setup
vibr: Enable Alarm
