Jimi IoT (Concox) CT10
Concox CT10 is a container GPS tracker with 3G support. The device features a container door close/open alert, automatic mode switching (land, sea & static mode), optional environment detection (temperature, humidity, and pressure), 3800mAh battery (up to 60 days working time), IP66 dust and waterproof casing, magnetic mount, and more.
Settings (3)
Flespi parses telemetry data from your Jimi IoT (Concox) CT10 into a standardized JSON and lets you send commands to Jimi IoT (Concox) CT10 via API.
    "device.type.id": "Jimi IoT (Concox) CT10",
How to send commands to Jimi IoT (Concox) CT10?
KD031 CAN data ID 0x0537,
KD031 CAN data ID 0x0526,
KD031 CAN data ID 0x0530,
KD031 CAN data ID 0x053B,
KD031 CAN data ID 0x010F,
KD031 CAN data ID 0xFEE9,
KD031 CAN data ID 0x0552,
KD031 CAN data ID 0x0111,
KD031 CAN data ID 0xEEF6,
KD031 CAN data ID 0x053D,
KD031 CAN data ID 0xF00A,
KD031 CAN data ID 0x0547,
Message ID 0x0800
device_info_ct10
imsi: IMSI
iccid: ICCID
Configure APN parameters
Server Setup
comm: Communication Mode
mode: Host Mode
