9 August, 2023
Jimi IoT (Concox) device data via API
How to obtain telematics data from any Jimi IoT (Concox) device via API.
You can obtain telematics data from any Jimi IoT (Concox) device in 6 easy steps:
  1. Create a free account on flespi.io.
  2. Set up the Concox channel in your flespi.io interface.
  3. Point a Jimi IoT device to your flespi account using the device configurator from Jimi IoT or by sending an SMS command to the device.
  4. Confirm that the device data is being received and parsed.
  5. Access Jimi IoT device data via API.
  6. Create a flespi device to access telemetry, apply plugins and analytics, and use long-term message storage.
flespi
flespi platform
2. Set up the Concox channel in flespi.io
flespi channels
The Channel dialogue box will show up. Enter the name for the channel (any text will suffice), select “concox” in the protocol_id drop-down menu, click 'SAVE + OPEN'.
flespi concox jimiiot setup
flespi channel setup
3. Point your Jimi IoT device to your flespi channel
You can do it with the Jimi IoT device configurator tool or by sending an SMS command to the device. The domain name and port to point to are located in the channel box.
The syntax of the SMS command is as follows:
server,1,<domain>,<port>,0#
While in the Channel dialogue box, click on the "Logs and Messages" tab. Inspect log records to confirm that your device has successfully connected to flespi. The presence of messages in the lower half of the screen will confirm that the incoming data is parsed. Please keep in mind that in as Logs section runs in realtime it will reflect any connection attempt. Hint: you can right-click on a message or log to show corresponding raw traffic.
flespi logs messages
flespi channel id
flespi rest api
flespi channels rest api
Fill in your channel ID in the 1-ch-selector field. Scroll a little lower until you see 'eye' button and click on it.
flespi channels rest api request
flespi json
Click on Telematics Hub, then on Devices, then '+' button in the lower right corner. You need to choose the proper device type ID and specify the device configuration. Hit Save when you're ready.
What's next?
