Jimi IoT (Concox) CT10
Concox CT10 is a container GPS tracker with 3G support. The device features a container door close/open alert, automatic mode switching (land, sea & static mode), optional environment detection (temperature, humidity, and pressure), 3800mAh battery (up to 60 days working time), IP66 dust and waterproof casing, magnetic mount, and more.
Parameters (372)
Settings (3)
Flespi parses telemetry data from your Jimi IoT (Concox) CT10 into a standardized JSON and lets you send commands to Jimi IoT (Concox) CT10 via API.
    "device.type.id": "Jimi IoT (Concox) CT10",
How to send commands to Jimi IoT (Concox) CT10?
Message ID 0x0010
Message ID 0x0010
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010
Message ID 0x0010
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010,
Message ID 0x0010
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010,
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010,
Message ID 0x0010,
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010,
Message ID 0x0010,
Protocol Number 0x39
Protocol Number 0x15
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010,
device_info_ct10
imsi: IMSI
iccid: ICCID
Configure APN parameters
Server Setup
comm: Communication Mode
mode: Host Mode
