Jimi IoT (Concox) EG02
Concox EG02 is an intelligent e-bike GPS tracker and alarm. The device features keyless power switch on (via the app or SMS), external siren support, automatic wheels lock, vibration, overspeeding, power off, geo-fence, and other alarms, intelligent anti-theft alarm, e-bike battery voltage detection, wide 9-90V voltage range, 270 mAh Li-Pol battery, and more.
Parameters (498)
Settings (17)
Flespi parses telemetry data from your Jimi IoT (Concox) EG02 into a standardized JSON and lets you send commands to Jimi IoT (Concox) EG02 via API.
    "device.type.id": "Jimi IoT (Concox) EG02",
How to send commands to Jimi IoT (Concox) EG02?
KD031 CAN data ID 0x0537,
KD031 CAN data ID 0x0526,
KD031 CAN data ID 0x0530,
KD031 CAN data ID 0x053B,
KD031 CAN data ID 0x010F,
KD031 CAN data ID 0xFEE9,
KD031 CAN data ID 0x0552,
KD031 CAN data ID 0x0111,
KD031 CAN data ID 0xEEF6,
KD031 CAN data ID 0x053D,
KD031 CAN data ID 0xF00A,
KD031 CAN data ID 0x0547,
Protocol Number 0x15
Message ID 0x0800
Arm/Disarm
arm
Arming/Disarming
enable: Arm
Battery Alarm
bat_alarm2
Battery Alarm Setup
battery: Enable Alarm
BLE Key
blekey
Set BLE key to the device
key: BLE Key
Center Number
center_number
phone: Center Number
Find
find
Find vehicle by triggering light and buzzer
GPS
gpsdup
Enable/Disable GPS Data Upload
Horn
ling
Horn Sounds Configuration
arm: Arm/Disarm
theft: Theft
search: Car Search
ring_time: Horn Ring Duration
vibration: Vibration
ring_interval: Duration Between Horn Rings
Displacement Alarm
move_alarm
Displacement Alarm Setup
move: Enable Alarm
Configure APN parameters
Power Alarm
power_alarm
Power Alarm Setup
power: Enable Alarm
Server Setup
comm: Communication Mode
mode: Host Mode
SOS Numbers
sos_numbers
SOS Phone Numbers Setup
delete: Delete Numbers
phone1: First Number
phone2: Second Number
phone3: Third Number
Remote ACC
star_acc
Remote ACC ON/OFF
GPS Tracking Interval
timer
GPS Data Upload Time Interval
time_on: ACC On Upload Interval
time_off: ACC Off Upload Interval
timezone
Time Zone Setup
Vibration Alarm
vibr_alarm4
Vibration Alarm Setup
vibr: Enable Alarm
Where
where
Obtain real-time position
