Jimi IoT (Concox) GK310
Concox GK310 is a high-performance personal 4G GPS tracker compatible with LTE/WCDMA/GSM network. The device features an HD touchscreen, two-way audio, listen-in, and various alarms.
Parameters (372)
Flespi parses telemetry data from your Jimi IoT (Concox) GK310 into a standardized JSON and lets you send commands to Jimi IoT (Concox) GK310 via API.
    "device.type.id": "Jimi IoT (Concox) GK310",
How to send commands to Jimi IoT (Concox) GK310?
Message ID 0x0010
Message ID 0x0010
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010,
Message ID 0x0010
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010,
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010,
Message ID 0x0010,
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010,
Message ID 0x0010,
Protocol Number 0x39
Protocol Number 0x15
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010,
Configure APN parameters
Server Setup
comm: Communication Mode
mode: Host Mode
