Jimi IoT (Concox) GT08
Concox GT08 is a vehicle GPS tracker in a IP65 dust- and waterproof casing. The device features remote fuel/power cutoff, wide operating voltage range, SOS alarm, vehicle battery protection, and more.
Parameters (344)
Settings (6)
Flespi parses telemetry data from your Jimi IoT (Concox) GT08 into a standardized JSON and lets you send commands to Jimi IoT (Concox) GT08 via API.
    "device.type.id": "Jimi IoT (Concox) GT08",
How to send commands to Jimi IoT (Concox) GT08?
abnormal.tier.pressure.alarm
Alarm bit 0x4D of Protocol Number 0xA5
Alarm bit 0x12 of Protocol Number 0xA5
Alarm bit 0x3E of Protocol Number 0xA5
Extended bit 0x04 of Protocol Number 0x39
can.brake.pedal.status
CAN brake pedal pressed
OBD Data ID 0x051F of Message subtype 0x01 of Transparent message type 0xF0 of Message ID 0x0900
Alarm bit 0x24 of Protocol Number 0xA5
Alarm bit 0x18 of Protocol Number 0xA5
Alarm bit 0x13 of Protocol Number 0xA5
Alarm bit 0x09 of Protocol Number 0xA5
Alarm bit 0x14 of Protocol Number 0xA5
Message ID 0x0300
Alarm bit 0x0E of Protocol Number 0xA5
Alarm bit 0x0F of Protocol Number 0xA5
Alarm bit 0x47 of Protocol Number 0xA5
Alarm bit 0x0D of Protocol Number 0xA5
Alarm bit 0x0B of Protocol Number 0xA5
Message ID 0x0300
Protocol Number 0xA2
Alarm bit 0x90 of Protocol Number 0xA5
Alarm bit 0x91 of Protocol Number 0xA5
Alarm bit 0x2A of Protocol Number 0xA5
Alarm bit 0x2B of Protocol Number 0xA5
Alarm bit 0x68 of Protocol Number 0xA5
Alarm bit 0x3D of Protocol Number 0xA5
Alarm bit 0x19 of Protocol Number 0xA5
Message ID 0x0300
Alarm bit 0x11 of Protocol Number 0xA5
Alarm bit 0x17 of Protocol Number 0xA5
Alarm bit 0x32 of Protocol Number 0xA5
Alarm bit 0x10 of Protocol Number 0xA5
Alarm bit 0x20 of Protocol Number 0xA5
Message ID 0x0300
Alarm bit 0x16 of Protocol Number 0xA5
Alarm bit 0x4B of Protocol Number 0xA5
Alarm bit 0x4F of Protocol Number 0xA5
Alarm bit 0x2D of Protocol Number 0xA5
Alarm bit 0x4E of Protocol Number 0xA5
Angle Report
angle_report
Angle Change Report Setup
angle_rep: Enable Angle Report
GPS Data Upload
gps_data_upload
GPS Data Upload Setup
mode: GPS Data Upload Mode
Heartbeat Interval
hbt_interval
hbt_on: ACC ON Interval
hbt_off: ACC OFF Interval
Configure APN parameters
Petrol/Electricity Control
relay
Petrol/electricity Control
Server Setup
comm: Communication Mode
mode: Host Mode
