Jimi IoT (Concox) GT230
Concox GT230 is a high-end GPS car tracker with international standard OBD II plug, which is specifically designed for the private cars. It’s easy to install, built-in backup battery, supports cut-off power alarm, acc detection, tracking location and upload fault diagnosis information and car condition in real time, widely applied to private cars and other motor vehicles with OBDII plug.
Parameters (372)
Flespi parses telemetry data from your Jimi IoT (Concox) GT230 into a standardized JSON and lets you send commands to Jimi IoT (Concox) GT230 via API.
    "device.type.id": "Jimi IoT (Concox) GT230",
How to send commands to Jimi IoT (Concox) GT230?
Message ID 0x0010
Message ID 0x0010
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010,
Message ID 0x0010
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010,
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010,
Message ID 0x0010,
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010,
Message ID 0x0010,
Protocol Number 0x39
Protocol Number 0x15
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010,
Configure APN parameters
Server Setup
comm: Communication Mode
mode: Host Mode
