Jimi IoT (Concox) GT710
Concox GT710 is a compact, waterproof GPS tracking unit for fixed asset tracking. The device features an IP66 casing capable of working in harsh environment, low battery, shutdown, and tamper alerts, a strong magnetic mount, and more. The device battery is enough to last for up to 3 years.
Parameters (353)
Settings (17)
Flespi parses telemetry data from your Jimi IoT (Concox) GT710 into a standardized JSON and lets you send commands to Jimi IoT (Concox) GT710 via API.
    "device.type.id": "Jimi IoT (Concox) GT710",
How to send commands to Jimi IoT (Concox) GT710?
abnormal.tier.pressure.alarm
can.brake.pedal.status
Protocol Number 0x39
Protocol Number 0x15
ACC Report
acc_report
ACC Change Report Setup
enable: Enable ACC Report
Analog Input Data Interval
analog_interval
Analog Input Data Upload Interval
ad_upload: Enable Upload of Analog Data
Angle Report
angle_report
Angle Change Report Setup
angle_rep: Enable Angle Report
External Battery Alarm
bat_alarm
External Battery Alarm Setup
battery: Enable Alarm
GPS Blind Alarm
blind_alarm
GSP Blind Area Alarm Setup
blind: Enable Alarm
Side Door Alarm
door_alarm
Door Alarm Setup
door: Enable Alarm
Find
find
Find vehicle by triggering light and buzzer
Geofence Alarm
geofence_alarm
Geofence Alarm Setup
fence: Enable Alarm
GPS Data Upload
gps_data_upload
GPS Data Upload Setup
mode: GPS Data Upload Mode
Heartbeat Interval
hbt_interval
hbt_on: ACC ON Interval
hbt_off: ACC OFF Interval
Displacement Alarm
move_alarm
Displacement Alarm Setup
move: Enable Alarm
Configure APN parameters
Overspeeding Alarm
overspeed_alarm
Overspeeding Alarm Setup
overspeed: Enable Alarm
Restart Device
Server Setup
comm: Communication Mode
mode: Host Mode
SOS Alarm
sos_alarm
SOS Alarm Setup
sos: Enable Alarm
Vibration Alarm
vibr_alarm
Vibration Alarm Setup
vibr: Enable Alarm
