Jimi IoT (Concox) GV20
Concox GV20 is a feature-rich 3G GPS tracker for vehicle monitoring working over WCDMA & GSM networks. The device features remote fuel/power cutoff, ignition status detection, instant alerts, and IP65 dust and waterproof casing.
Parameters (356)
Settings (14)
Flespi parses telemetry data from your Jimi IoT (Concox) GV20 into a standardized JSON and lets you send commands to Jimi IoT (Concox) GV20 via API.
    "device.type.id": "Jimi IoT (Concox) GV20",
How to send commands to Jimi IoT (Concox) GV20?
Protocol Number 0x39
Protocol Number 0x15
Center Number
center_number
phone: Center Number
Delayed Defense
defense
Delayed Defense Setup
delay: Delayed Defense
GPS Data Upload
gps_data_upload
GPS Data Upload Setup
mode: GPS Data Upload Mode
Heartbeat Interval
hbt_interval
hbt_on: ACC ON Interval
hbt_off: ACC OFF Interval
Displacement Alarm
move_alarm
Displacement Alarm Setup
move: Enable Alarm
Configure APN parameters
Restart Device
Petrol/Electricity Control
relay_action
Retrol/electricity Control
Server Setup
comm: Communication Mode
mode: Host Mode
SOS Numbers
sos_numbers
SOS Phone Numbers Setup
delete: Delete Numbers
phone1: First Number
phone2: Second Number
phone3: Third Number
Status
status
Update status of the device
timezone
Time Zone Setup
Vibration Alarm
vibr_alarm
Vibration Alarm Setup
vibr: Enable Alarm
Where
where
Obtain real-time position
