Jimi IoT (Concox) JM-LL01
Concox JM-LL01 is an asset GPS tracker with LTE support, up to 3 years of battery life, and a magnetic mount. The device features a 10,000 mAh Li-Pol backup battery, tamper alert, IP65 dust & water-resistant casing, and more.
Parameters (372)
Settings (16)
Flespi parses telemetry data from your Jimi IoT (Concox) JM-LL01 into a standardized JSON and lets you send commands to Jimi IoT (Concox) JM-LL01 via API.
    "device.type.id": "Jimi IoT (Concox) JM-LL01",
How to send commands to Jimi IoT (Concox) JM-LL01?
Message ID 0x0010
Message ID 0x0010
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010,
Message ID 0x0010
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010,
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010,
Message ID 0x0010,
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010,
Message ID 0x0010,
Protocol Number 0x39
Protocol Number 0x15
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010,
Battery Alarm
bat_alarm2
Battery Alarm Setup
battery: Enable Alarm
Check
check
Obtain general information about the device. The response will be stored as a message
Delayed Defense
defense
Delayed Defense Setup
delay: Delayed Defense
G-Sensor sensitivity
g_sens_level
G-Sensor sensitivity level
level: Level
Heartbeat
hrbt_ival
Heartbeat interval
ival: Interval
Configure APN parameters
Overspeeding Alarm
overspeed_alarm
Overspeeding Alarm Setup
overspeed: Enable Alarm
Restart Device
Server Setup
comm: Communication Mode
mode: Host Mode
Status
status
Update status of the device
Tamper Alarm
tamper_alarm
Tamper Alarm Setup
tamper: Enable Alarm
timezone
Time Zone Setup
Vibration Alarm
vibr_alarm
Vibration Alarm Setup
vibr: Enable Alarm
Voice alarm
voice_alarm
Voice Alarm Setup
voice: Enable Alarm
Where
where
Obtain real-time position
Working Mode
working_mode
Device working mode settings
mode: Working Mode
