Jimi IoT (Concox) JM-LL301
Concox JM-LL301 is a 4G LTE Cat.1 asset GPS tracker with an ultra-long life battery. The device features GPS + BDS + LBS + Wi-Fi positioning, remote listen-in, multiple working modes, multiple alerts, 10,000 mAh battery, Bluetooth, magnetic mount, IP65 casing, and more.
Parameters (355)
Settings (10)
Flespi parses telemetry data from your Jimi IoT (Concox) JM-LL301 into a standardized JSON and lets you send commands to Jimi IoT (Concox) JM-LL301 via API.
    "device.type.id": "Jimi IoT (Concox) JM-LL301",
How to send commands to Jimi IoT (Concox) JM-LL301?
Protocol Number 0x39
Protocol Number 0x15
Battery Alarm
bat_alarm2
Battery Alarm Setup
battery: Enable Alarm
Check
check
Obtain general information about the device. The response will be stored as a message
Configure APN parameters
Sensitivity
sens_level
level: Level
Server Setup
comm: Communication Mode
mode: Host Mode
Tamper Alarm
tamper_alarm
Tamper Alarm Setup
tamper: Enable Alarm
Exit Tamper Alarm
tamper_cancel
timezone
Time Zone Setup
Vibration Alarm
vibr_alarm
Vibration Alarm Setup
vibr: Enable Alarm
Where
where
Obtain real-time position
