Jimi IoT (Concox) JM-LL302
Concox JM-LL302 is a 4G LTE Cat.1 asset GPS tracker with an ultra-long life battery and light sensor. The device features GPS + BDS + LBS + Wi-Fi positioning, remote listen-in, multiple working modes, multiple alerts, 10,000 mAh battery, Bluetooth, magnetic mount, optional temperature and humidity sensors, optional door status detection, IP65 casing, and more.
Parameters (344)
Settings (10)
Flespi parses telemetry data from your Jimi IoT (Concox) JM-LL302 into a standardized JSON and lets you send commands to Jimi IoT (Concox) JM-LL302 via API.
    "device.type.id": "Jimi IoT (Concox) JM-LL302",
How to send commands to Jimi IoT (Concox) JM-LL302?
abnormal.tier.pressure.alarm
Alarm bit 0x4D of Protocol Number 0xA5
Alarm bit 0x12 of Protocol Number 0xA5
Alarm bit 0x3E of Protocol Number 0xA5
Extended bit 0x04 of Protocol Number 0x39
can.brake.pedal.status
CAN brake pedal pressed
OBD Data ID 0x051F of Message subtype 0x01 of Transparent message type 0xF0 of Message ID 0x0900
Alarm bit 0x24 of Protocol Number 0xA5
Alarm bit 0x18 of Protocol Number 0xA5
Alarm bit 0x13 of Protocol Number 0xA5
Alarm bit 0x09 of Protocol Number 0xA5
Alarm bit 0x14 of Protocol Number 0xA5
Message ID 0x0300
Alarm bit 0x0E of Protocol Number 0xA5
Alarm bit 0x0F of Protocol Number 0xA5
Alarm bit 0x47 of Protocol Number 0xA5
Alarm bit 0x0D of Protocol Number 0xA5
Alarm bit 0x0B of Protocol Number 0xA5
Message ID 0x0300
Protocol Number 0xA2
Alarm bit 0x90 of Protocol Number 0xA5
Alarm bit 0x91 of Protocol Number 0xA5
Alarm bit 0x2A of Protocol Number 0xA5
Alarm bit 0x2B of Protocol Number 0xA5
Alarm bit 0x68 of Protocol Number 0xA5
Alarm bit 0x3D of Protocol Number 0xA5
Alarm bit 0x19 of Protocol Number 0xA5
Message ID 0x0300
Alarm bit 0x11 of Protocol Number 0xA5
Alarm bit 0x17 of Protocol Number 0xA5
Alarm bit 0x32 of Protocol Number 0xA5
Alarm bit 0x10 of Protocol Number 0xA5
Alarm bit 0x20 of Protocol Number 0xA5
Message ID 0x0300
Alarm bit 0x16 of Protocol Number 0xA5
Alarm bit 0x4B of Protocol Number 0xA5
Alarm bit 0x4F of Protocol Number 0xA5
Alarm bit 0x2D of Protocol Number 0xA5
Alarm bit 0x4E of Protocol Number 0xA5
Battery Alarm
bat_alarm2
Battery Alarm Setup
battery: Enable Alarm
Check
check
Obtain general information about the device. The response will be stored as a message
Configure APN parameters
Sensitivity
sens_level
level: Level
Server Setup
comm: Communication Mode
mode: Host Mode
Tamper Alarm
tamper_alarm
Tamper Alarm Setup
tamper: Enable Alarm
Exit Tamper Alarm
tamper_cancel
timezone
Time Zone Setup
Vibration Alarm
vibr_alarm
Vibration Alarm Setup
vibr: Enable Alarm
Where
where
Obtain real-time position
