Jimi IoT (Concox) JM-LL303
Concox JM-LL303 is a 4G solar-powered GPS tracker designed for construction vehicles and vessels. The device features a solar panel, a magnetic charger, multiple alerts, Bluetooth accessories compatibility, RFID reader (optional), 10,000mAh Li-Polymer battery, an IP67 waterproof casing, and more.
Parameters (376)
Settings (10)
Flespi parses telemetry data from your Jimi IoT (Concox) JM-LL303 into a standardized JSON and lets you send commands to Jimi IoT (Concox) JM-LL303 via API.
    "device.type.id": "Jimi IoT (Concox) JM-LL303",
How to send commands to Jimi IoT (Concox) JM-LL303?
Message ID 0x0010
Message ID 0x0010
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010,
Message ID 0x0010
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010,
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010,
Message ID 0x0010,
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010,
Message ID 0x0010,
Protocol Number 0x39
Protocol Number 0x15
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010,
Battery Alarm
bat_alarm2
Battery Alarm Setup
battery: Enable Alarm
Check
check
Configure APN parameters
Sensitivity
sens_level
level: Level
Server Setup
comm: Communication Mode
mode: Host Mode
Tamper Alarm
tamper_alarm
Tamper Alarm Setup
tamper: Enable Alarm
Exit Tamper Alarm
tamper_cancel
timezone
Time Zone Setup
Vibration Alarm
vibr_alarm
Vibration Alarm Setup
vibr: Enable Alarm
Where
where
Obtain real-time position
