Jimi IoT (Concox) JM-VL01
Concox JM-VL01 is a powerful and easy-to-install 4G/LTE GPS tracker. The device features LTE, UMTS & GSM network support, ACC detection for ignition status, remote cut-off (petrol/power), Wi-Fi hotspot, emergency SOS button, RS485 interface, 450mAh Li-Pol battery, IP65-compliant casing, and more.
Parameters (494)
Flespi parses telemetry data from your Jimi IoT (Concox) JM-VL01 into a standardized JSON and lets you send commands to Jimi IoT (Concox) JM-VL01 via API.
    "device.type.id": "Jimi IoT (Concox) JM-VL01",
How to send commands to Jimi IoT (Concox) JM-VL01?
KD031 CAN data ID 0x0537,
KD031 CAN data ID 0x0526,
KD031 CAN data ID 0x0530,
KD031 CAN data ID 0x053B,
KD031 CAN data ID 0x010F,
KD031 CAN data ID 0xFEE9,
KD031 CAN data ID 0x0552,
KD031 CAN data ID 0x0111,
KD031 CAN data ID 0xEEF6,
KD031 CAN data ID 0x053D,
KD031 CAN data ID 0xF00A,
KD031 CAN data ID 0x0547,
Protocol Number 0x39
Protocol Number 0x15
Configure APN parameters
Server Setup
comm: Communication Mode
mode: Host Mode
