Jimi IoT (Concox) JM-VL03
Concox JM-VL03 is an easy-hidden 4G LTE vehicle GPS tracker for fleet management. The device features driving behavior analysis, remote cut-off, ignition detection, multiple alerts (tamper, vibration, towing, geofencing, speeding, etc.), and more.
Parameters (372)
Settings (5)
Flespi parses telemetry data from your Jimi IoT (Concox) JM-VL03 into a standardized JSON and lets you send commands to Jimi IoT (Concox) JM-VL03 via API.
    "device.type.id": "Jimi IoT (Concox) JM-VL03",
How to send commands to Jimi IoT (Concox) JM-VL03?
Message ID 0x0010
Message ID 0x0010
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010
Message ID 0x0010
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010,
Message ID 0x0010
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010,
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010,
Message ID 0x0010,
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010,
Message ID 0x0010,
Protocol Number 0x39
Protocol Number 0x15
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010,
Configure APN parameters
Restart Device
Petrol/Electricity Control
relay
Petrol/electricity Control
Server Setup
comm: Communication Mode
mode: Host Mode
Where
where
Obtain real-time position
